Old 01-03-2006, 07:05 AM   #1
ogkush
ogkush is on a distinguished road
Default water build up in spare tire wheel, 87 supra---any solutions??????
some way some how water is leeking into the spare tire wail in the trunk, i dont think its coming from the top of the car cus the trunk carpet never feels wet.....i herd supras leak any detail on this?
ogkush is offline   Reply With Quote
Old 01-03-2006, 09:24 AM   #2
best thing you can do is get someone inside the car with ur back seats down and you outside it hosing it down
aim it straight down the trunk area to see if your rubber is leaking first
if no drips then try at the bottom of the rear windscreen and rear wiper and see if that leaks
if still no drips then try aiming it straight at your tail lights
if it leaks when aimed at your taillights then the red lense is parting away from the black frame... silicon can seal up that gap and hopefully no more water
it could be that your taillight gaskets are old and corroded so you may need some new ones of those
tomorrow if i get time i will take pics on how i fixed our taillight leak
Old 01-05-2006, 02:18 AM   #3
Smile hatch leaks
There has been many threads on the hatch leaking. It is a common problem. The water will work its way down to the lowest point.
You can pull the rubber plug under the spare to let the water out.
Mine does it too. Many (me too) feel it comes from the glass at the bottom on the hatch. Fixing it can be a bit of work.
Also...check each rear wheel well (where the jack is stored) L&R. If there is water in them, you can pull the rubber plugs out. I leave mine out permanently.
Old 01-23-2006, 01:07 AM   #4
Isphius
Isphius's Avatar
I have a similar problem...my rear hatch fills with water amd when i open it it all pours in the trunk, not a lot of water only about 1/4 cup but still i dont want it in there. i think it may be the rear wiper or window seal. anyone fix one of these before?
Old 06-30-2011, 07:17 AM   #5
suijin-
suijin-'s Avatar
suijin- is on a distinguished road
I also have the same problem but in MKIV supra, ive got it schedualed in to get a full bodykit and full respray in a couple of weeks time, if its something the panel beater can fix can you please give me hints on how to identify where the waters coming from? thanks
suijin- is offline   Reply With Quote
Old 09-17-2011, 09:42 PM   #6
finafantasy7
finafantasy7's Avatar
finafantasy7 is on a distinguished road
something i suggest is that you look for rust in ur spair wheel area very common i just sand it down and primmerd it so rust doesnt eat away the section check ever so oven when rains comes around which is hardly in vegas
finafantasy7 is offline   Reply With Quote
Supra space saver wheel question aquanuke Non-Generation Specific Questions 0 03-25-2008 10:24 PM
HELP! Standing water in my spare tire well finaltable MKIII Supra 11 12-28-2007 11:35 PM
