Old 11-29-2005, 06:33 PM   #1
87sleeper
87sleeper is on a distinguished road
Question will my ct-26 blow if I don't turn down boost?
hi, i'm new to the forum and modding my supra...I recently shimmed my wastegate (link form supra_girl I believe) with 4 washers, that gives me about 9psi...but yesterday I installed a complete turbo-back 3 inch. exhaust and removed the cat. I heard that going with a "straight pipe" setup your boost will increase automatically do to less restriction, is this true??
right now I don't have and "accurate" boost gauge so I don't want to break my turbo...
any help would be great, thanks.
87sleeper is offline   Reply With Quote
Old 11-29-2005, 06:42 PM   #2
joel w
joel w's Avatar
i just upgraded my turbo back to 3" and yes it upped my boost a few lbs.. might be a good idea so as not to over spin the ct26...
Old 11-29-2005, 08:20 PM   #3
skunk
skunk's Avatar
Default 14 psi
I shimed my waste gate and run a straight through exaust I think you will be fine you will only hit max boost running at high speeds, 12 psi is fuel cut, so i would just work of that, play with it if you hit fuel cut, back off a little, and you really cant break the turbo doing what your talking about, the ct26 is more than capable of pushing 14 to 15 psi stock
Old 11-29-2005, 10:09 PM   #4
joel w
joel w's Avatar
thats what i used to think before i toasted 2 turbos and did the research.. anything over 13psi will only create heat and overspin it.. it will not flow anymore air over 13... check it out...
Old 11-30-2005, 04:10 AM   #5
skunk
skunk's Avatar
Default yeah
yeah...i thought it was any thing over 15, but your probly rite...my point was that he would hit fuel cut before any thing could happen, correct me if im wrong.
Old 11-30-2005, 04:25 AM   #6
joel w
joel w's Avatar
ya fuel cut is 14.5 i think? the ct-26 can make 20psi but it wont last long at all..
As i was told by several turbo makers/rebuilders that at 13psi, the ct-26 is at its max for airflow and is spinning way too fast even at 13psi. most say that its under sized even at 8 psi. so there is no gain from 13-15psi.. only heat is created which really means less power.. hope this helps.. most people suggest 9 or 10 psi on the stock. im running with a 50 trim upgrade and people still tell me to keep it under 11psi..
anyone agree or disagree here?
Old 11-30-2005, 05:43 AM   #7
sakara
sakara's Avatar
sakara is on a distinguished road
the all tracs also have the ct26 turbo... They will boost to 14-15 safely... anything higher then that running constantly and u can risk the big boom, lol.
sakara is offline   Reply With Quote
Old 11-30-2005, 06:23 AM   #8
skunk
skunk's Avatar
thanks. because i was under the influence that i could boost more. I have an 88 alltrac( striped bare ready to build into a beast ) I will keep that in mind, it seems were all on the same page
Old 11-30-2005, 02:20 PM   #9
SupraMan1784
i suggest leaving the 26 under 14 psi, as jwills said he toasted two turbos, teh 3'' should increase your flow as long as it continues all the way to the back and it will create a little more boost....joel man its tough in this forum cause everyone mainly has a 7m....i like hanging around in teh other forum where they got a bunch of 1jzs and a dude with a 2jz...there is more fun, here is a little more technical
Now: Saving for an MKIV
Broken Rides:
Old 11-30-2005, 03:16 PM   #10
lifesnotfair
Default Hrm...
What other forum? MKIV or what?
wont hold boost Supraman MKIII Supra 12 04-19-2007 04:52 AM
