Old 11-24-2005, 05:42 AM   #1
vladkalika
vladkalika is on a distinguished road
Default rough idle problem
Just bought 1989 Supra Turbo (4th one I've owned) with bad exhaust manifold gasket. So I changed it out along with a bunch of old cracked hoses and installed new spark plugs.
Now it idles extremely rough, wants to stall, and from the tailpipe it sounds like it's missing (definitely not smooth purr it used to have). It also seems to run hot; temp gauge shows normal but underhood temp especially around turbo is blistering hot.
I double-checked ignition wires and all the sensors/plugs. Any suggestions what it might be?
vladkalika is offline   Reply With Quote
Old 11-24-2005, 08:24 AM   #2
Well...if it ran smooth before you messed with it???? Check and double check, and back track your steps. You must be missing something. Possibly hooked up some vacuum lines wrong. Are the plug wires on correctly. Pull the plugs and check the gaps, and quality of the plugs (cracked ceramics, etc).
Misses are caused by 2 things....bad spark...or bad fuel mixture. Except of course, bad compression (usually due to a valve problem).
Old 11-24-2005, 05:40 PM   #3
rays87turbo
rays87turbo is on a distinguished road
Did you remove the CPS when you took off the exhasut manifold? If so you should probably check to see it is back on correctly, and check the timing.
rays87turbo is offline   Reply With Quote
Old 11-24-2005, 07:35 PM   #4
vladkalika
I did remove CPS. Timing check is next.
thanks guys
Old 11-27-2005, 01:19 AM   #5
vladkalika
Got the timing set, purrs like a kitten now.
Now that the car is running well, time for upgrades. Downpipe, boost controller, cold air intake......
Old 11-28-2005, 10:07 PM   #6
intake, exhaust, little boost
then save for hg
Rough Idle????? ZauggIt1 MKIII Supra 2 11-11-2006 08:50 PM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
Idle Problem. Please Help panicos MKIV Supra 18 01-01-2006 06:56 PM
