Old 11-22-2005, 05:44 PM   #1
jride1999
jride1999 is on a distinguished road
Default question
whats the difference in turbo 2.5 inch exhaust an non turbo 2.5in exhaust?And whats the best turbo to go with on a 1989 supra with lil lag?
jride1999 is offline   Reply With Quote
Old 11-23-2005, 09:45 PM   #2
Burn N' Up
Burn N' Up's Avatar
The exhaust is the same, except a N/A has a manifold and headers, a turbo has a collector, turbo, elbow and down pipe. I almost have no idea what your asking in this post but... The bigger a turbo is the more peak boost possible, however it generally takes longer to spool. Smaller turbo with means faster spool with less peak pressure. You can always twin turbo but that means an engine swap =0
Old 11-24-2005, 12:33 AM   #3
rays87turbo
rays87turbo is on a distinguished road
The answer to that question can only be determined by knowing what your supporting mods are, and what your ultimate goals are. If you just want a freshly rebuilt turbo that will deliver more power while not having much lag, you should probably just have your stock turbo upgraded.
rays87turbo is offline   Reply With Quote
Old 11-24-2005, 09:36 AM   #4
Reeves
Reeves is on a distinguished road
What kind of upgrades are you talking about? That is exactly what I want to do somewhere down the line, but as of now have no idea how to go about it.
Reeves is offline   Reply With Quote
Old 11-24-2005, 09:38 AM   #5
ryemann32
ryemann32's Avatar
ryemann32 is on a distinguished road
what kind of car are u starting with so i can try to help u out
ryemann32 is offline   Reply With Quote
Old 11-24-2005, 05:32 PM   #6
rays87turbo
You can have your stock turbo upgraded, where the put a bigger intake compressor, and possibly have the exhaust wheel clipped. This increases the efficiency range of the ct-26 to about 18 psi...if you get a .60 trim, where the stock one becomes inefficient around 14psi. You may be able to find a local place that rebuilds turbos, they should be able to do it. Otherwise you will have to ship it somewhere. Majestic turbo here in Dallas does a good job. I've also heard Precision turbo somewhere up north, maybe in canada, does an excellent job as well.
Old 11-24-2005, 09:09 PM   #7
Reeves
Awesome. Any idea what all that would cost?
Old 11-24-2005, 10:33 PM   #8
Burn N' Up
Burn N' Up's Avatar
450 for rebuild and upgrade to 50mm trim from turbonetics
Old 11-26-2005, 10:04 AM   #9
lil_dcb7
lil_dcb7's Avatar
lil_dcb7 is on a distinguished road
is it possible to use a turbo exhaust on an NA setup?
lil_dcb7 is offline   Reply With Quote
Old 11-26-2005, 02:20 PM   #10
jride1999
thanx, i have a 1989 turbo supra.My goal in mods are 3in cat back exhaust,3in downpipe and boost controller. i heard if i go with a bigger turbo it will have slower take of time do to lag.I found a 2.5 pacestter cat back for a na turbo for $200.Hks has a 2.5 cat back for a turbo for $700.My question is whould they both be the same in power,sence they are diff brands? now if I have the heads shaved will,it give me more power? an whatsize metal head gasket whould i need,im new to the supra thing thanx
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
