Old 11-05-2005, 09:32 PM   #1
Burn N' Up
Burn N' Up's Avatar
Default Lubing poly bushings?
Anybody have any info/opinions on lubing or not lubing poly suspension bushings? Thanks
Old 11-06-2005, 05:40 AM   #2
mrnickleye
mrnickleye's Avatar
I was looking at a poly set for mine. It comes with some syn. lube for installation. Dont think you can properly lube the bushings after they're installed.
Old 11-08-2005, 07:27 AM   #3
Burn N' Up
Burn N' Up's Avatar
Oh, i Know that, but what do you mean synthetic lube? Like a gear oil? gimme some suggestions. just got mine in and wanna get them installed.
Old 11-09-2005, 08:26 AM   #4
mrnickleye
mrnickleye's Avatar
Talking
Its synthetic grease. You can get it at any parts house. I bought some for brake calipers, cause it was in a toothpaste tube, dark, cheap enough, heat resistant, and lasts forever. You'll only need a small amount of coating on the parts.
Old 11-10-2005, 05:48 PM   #5
Burn N' Up
Burn N' Up's Avatar
Thanks Homie, I've got some red line wheel bearing grease i'll use, sound about right?
Automatic shift lever bushings mrnickleye MKIII Supra 0 10-15-2008 05:24 PM
ma70 polyurethane subframe bushings ronniek MKIII Supra 0 03-22-2007 07:04 AM
Rear Suspension Bushings, 89 MKIII mrnickleye MKIII Supra 4 02-07-2007 06:15 AM
Bushings.. TRAFIK Non-Generation Specific Questions 1 11-07-2005 07:22 PM
poly or stock bushes Supro MKIII Supra 10 10-11-2005 12:56 PM
