Old 02-03-2019, 01:42 AM   #1
SupraMiniPooj
SupraMiniPooj is on a distinguished road
Question Can't get alignment right
I just finished a major suspension overhaul/upgrade (tein coilovers, poly bushings all around, ST sway bars, new outer tie rods and lower ball joints) on my 1988 MKIII Turbo. Took it to the alignment shop and they can't get the front left tire straight. It is still way toe out and the tie rod end is already bottomed out on the inner tie rod. The right they could only just get straight, but its bottomed all the way out too. I'm going the see if the inner tie rod backed out at all as I was loosening the outer, but I didn't notice anything off as I hat to replace that side boot as well. Wheels are OE and tires are standard. I am pretty sure the steering wheel tracked straight last I drove the car, but it's been a while......
SupraMiniPooj is offline   Reply With Quote
Tags
alignment, tie rod
mk3 alignment Q? supraman3000 MKIII Supra 10 08-08-2011 09:39 PM
hood alignment issues Crop MKIII Supra 2 03-22-2011 11:53 PM
Alignment issue 91ma70 MKIII Supra 3 07-24-2010 08:06 PM
checking out an 86 mk3 tomorrow cvbikeguy MKIII Supra 272 03-25-2010 05:01 AM
alignment of EGR valve Serge MKIII Supra 1 05-06-2008 01:43 PM
