Old 03-04-2017, 06:12 PM   #1
JIMMY JO BOB
JIMMY JO BOB is on a distinguished road
Question Pps steering rack in non pps 87 supra nt ?
I screwed up & bought the wrong Rack - That's what I get for buying it after Midnite - Of course PPS Solenoid Pressure Valve gives u "parking mode PS boost" for ease of steering when idling per the ECU via Solenoid Pressure Valve on this newer year Rack - SO>>> I'll never NEVER see parking mode PS boost which would be fine of course ... BUT it also boosts "progressively" thru speeds so unsure how that's gonna turn out...
I have this helpful jewel thanx to yall:
http://www.cygnusx1.net/Supra/Librar...aspx?S=SR&P=90
87 NT
JIMMY JO BOB is offline   Reply With Quote
Old 03-05-2017, 03:10 AM   #2
JIMMY JO BOB
Question
Well it fits - The Hi Pressure Line w/ Banjo will line up - The reason the PPS Rack (& maybe all the later year MKIII Racks) are an inch or so longer on Passenger side is that there's no Steering Damper hookup on this newer MKIII Rack - I need the Solenoid Pressure Valve that's part of & plugs into Toyota Pressure Valve PN (44020-50090) - Not having a lotta luck finding one online so if u know source let me know...
- I did find this though:
- "but what I've learned is even with it disconnected, there will still be power assistance"
87 NT
Old 04-24-2017, 02:02 PM   #3
JIMMY JO BOB
Smile
Works great w/no electrical input to PPS Valve - Steering is weighted nicely w/car moving - Idle up feature keeps it fm being too heavy when stopped running stock size Falken Tires - Absolutely ZERO effect fm having no Steering Dampener being I have PPS Rack.
Biggest thing about Rack replacement is to make sure that u clean up the collapsable part of column & lube that up VERY well - That's because u use that travel to mate Shaft Spline fm Rack to Universal at Firewall AFTER u adjust Tie Rod Threads equally to 1/2 inch or so & secure Steering Wheel at center w/bungies - If u have Air Bag make sure u secure Steering Wheel at Center w/bungies BEFORE separating Shaft fm Universal at Firewall because of Clock Spring limits - Older cars like mine have no Clock Spring.
87 NT
Old 05-03-2017, 11:41 AM   #4
yale
yale is on a distinguished road
Thanks for the information.
Going to have to replace mine soon ('86.5 Supra). When I replaced the tie rods I ran into an issue with dampening mount being in the way. Simply cut it off and kept on going. Hasn't been a problem at all.
yale is offline   Reply With Quote
'83 Supra power steering problems OneBgBdArtemis MKII Supra 1 07-06-2014 04:54 AM
88 Steering Wheel on 91 Supra nick124 MKIII Supra 1 01-20-2013 06:36 PM
Fixed Rack and Pinion but steering still does not work 91supraturbobrown MKIII Supra 3 03-29-2011 04:22 AM
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
