Old 10-12-2014, 05:11 AM   #1
87WhiteTurbo
87WhiteTurbo's Avatar
87WhiteTurbo is on a distinguished road
Default LC-1 narrowband output trickery, wonky boost gauge
Just got my Supra! Have some questions, if you fellow Supra owners would be so kind.
Anyone using the narrowband output on their wideband to trick the ECU into running lean during closed loop by scaling the voltage? Like ECU sees 14.7:1, but you're running at 15.7:1 actual AFR? I know its been done on other cars, just curious if anyone is doing it with the Supra.
Also, is the stock boost gauge usually wonky? Mine only seems to work at all once I hit nearly full boost. The car has an HKS gauge in a pod that works fine, but the needle on the stocker only moves at all once I'm well into boost, and never shows vac.
87WhiteTurbo is offline   Reply With Quote
Boost gauge questions RyanDronsfield MKIII Supra 4 12-30-2011 04:04 AM
Boost gauge doesn't register anything Supra Saiyan MKIII Supra 6 09-14-2010 05:09 AM
Digital dash boost gauge... MA70-3.0GT MKIII Supra 3 12-04-2009 07:32 PM
Boost gauge install location Durandal MKIV Supra 1 07-26-2009 11:55 AM
Small Boost Gauge Chambers MKIII Supra 8 08-18-2007 05:30 PM
