Old 03-03-2014, 02:55 AM   #1
Hayloe
Hayloe is on a distinguished road
Default How to tell between a Manual and Auto transmission Wire Harness?
So I came across a wire harness for my 1989 Supra 7M-GTE today at the junkyard, I just happened to forget to check what type of transmission the car had.
What are the differences between the manual and auto wire harness's? I found a post saying if its an auto i'm going to have to put a jumper in to bypass the neutral safety switch?
Hayloe is offline   Reply With Quote
Old 03-04-2014, 12:46 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
Well, mine is a manual, and I have two wire connectors. A two-prong connector on the side for the reverse lights and a small connector on top for the ABS sensor. I believe the automatic transmission connector is much larger then the two-prong connector on the manual, since the transmission is computer-shifted and includes the gear selector NSS.
Manual to Auto, Killswitch, Drive shaft wayzhack MKIII Supra 7 10-13-2010 02:35 AM
Engine harness question between auto and manual gambit1982 MKIV Supra 4 05-25-2010 05:34 AM
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
auto wiring harness on manual? mizuboi MKIII Supra 0 02-22-2007 07:15 PM
