Old 05-06-2013, 04:21 PM   #1
ChadxScene
ChadxScene is on a distinguished road
Default coolant issue need help
I'm new to Supras, just bought a 1987 Toyota Supra Turbo. Got it pretty cheap, but it has some issues. the main one holding me up right now is this coolant issue. Here are some picture of where the coolant is leaking out of. I've been trying to figure out what it is or what it was supposed to be for the past few days.
This is a picture to give you an idea of where its at
This is a picture of what is leaking.
Yes I know my engine is dirty, I just replaced valve cover gaskets to stop an oil leak, I haven't gotten a chance to clean the engine up all the way, just trying to get it running properly.
ChadxScene is offline   Reply With Quote
Old 05-06-2013, 11:12 PM   #2
It's supposed to be capped on LHD models, on RHD models the other side is capped.
Old 05-06-2013, 11:19 PM   #3
ChadxScene
So pretty much I just need to replace the cap and I'll be good?
Old 05-06-2013, 11:19 PM   #4
ChadxScene
Angry
Also, where would be place I could find said cap?
Old 05-07-2013, 05:17 AM   #5
btwilson86
Super Moderator
btwilson86's Avatar
Yup, just need to replace the cap. You can probably get one from Toyota, you may be able to find one at a parts store. Dorman / Motormite usually have some heater hose caps in a blister pack in the "Help!" section
Old 05-07-2013, 03:43 PM   #6
Make sure it's not a vacuum cap and also if it's after-market try to find one that's fabric reinforced.
Old 05-08-2013, 02:21 AM   #7
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
I just got one at the dealer the part number is 90339-16001. It's simply called a plug. The cost was $4.14 You may be able to stop the leak by tightening the clamp a bit. Looks like the oil has gotten to it and it may be deteriorated. One thing to hope for is that the pipe itself is not corroded and thin walled. I have seen some rotten ones. You need to get the oil leak under control or at least wrap the new plug with some aluminum foil.
Old 05-11-2013, 06:47 PM   #8
ChadxScene
I got 2 of them thru the shop i work at for $3.00 now its fixed and driving again. The oil leak is fixed. when i bought the car a month ago the valve covers were leaking bad. Thats the first thing i fixed tho. now its just time to sit down and start repairing everything thing else.
Old 05-13-2013, 11:23 PM   #9
Bru
Bru's Avatar
The valve covers have always been a source of problems for oil leaks. I have ended up using stainless steel Allen head screws with a drop of red Loctite on the threads to keep them from coming loose again. It makes it harder to get them out after the Loctite has set, that's why a Allen head screw works best. I also use a thin layer of black silicone to seal the valve cover gasket in the groove and on the contact side for added insurance.
Another place oil can leak are the spark plug valley plate 14 mm hex plugs if oil is collecting around your spark plugs after sealing the valve covers. A dab of silicone works here as well then torque them down. Keep an eye on your front and rear coolant by pass 90-degree elbows. When they get old or oil soaked they can become soft and rupture. I check by giving them a little squeeze when the engine is cold. It doesn't hurt to get a rag out and start cleaning up to your engine area. That way you can spot new trouble easier plus it looks good!
Old 05-14-2013, 10:33 AM   #10
MA70-3.0GT
MA70-3.0GT's Avatar
Originally Posted by Bru View Post
"snip".....It doesn't hurt to get a rag out and start cleaning up to your engine area. That way you can spot new trouble easier plus it looks good!
Agreed, plus with the oil soaking it's had recently now is the best time as the 25+ years of gunk buildup is soft and easily got rid of at the moment. A few thousand miles of no leak & it'll be baked on again...
Gotta love how modern the 7M engine still looks when its all clean & sparkly
Auto Supra Coolant hose pressure and return leak to oil pan and filter area? rjSupra MKIII Supra 45 01-18-2011 12:12 AM
coolant issue suicidal MKIII Supra 2 12-06-2010 03:04 AM
Had overheating issue and Coolant leaking from intake Side?? Raysupra MKIII Supra 6 04-07-2010 05:20 PM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Funky engine coolant issue shirkinator Non-Generation Specific Questions 1 06-22-2009 08:37 AM
