Old 07-11-2012, 02:08 AM   #21
Joefishizzle
Joefishizzle is on a distinguished road
This is what Vatozone pads look like after 10,000 miles.
-Happy to report....4th day of driving. no vibration
Joefishizzle is offline   Reply With Quote
Old 07-11-2012, 03:02 AM   #22
pandrade
pandrade is on a distinguished road
I would go to the advanced and complain and try to haggle a discount on my next purchase
(did you bed those pads in properly by chance? I'm using advanced cheapest pads as daily and my auto crosser and have had no issues)
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 07-11-2012, 04:12 AM   #23
The vibration could have caused them to crack like that. The cracking of the friction media again seems to me to be more likely to be a symptom than the source of the problem.
Old 07-11-2012, 10:03 AM   #24
Joefishizzle
i totally agree. however im not saying that they are the best pads. autozne only makes one pad for our car....not stock. i mean produce. the cheapest lowest grade pad. i broke them in properly. i rarely ever use my brakes to be honest. even in LA traffic...i engine brake/downshift alot.
Well when i took off the booster i had about a quart of brake fluid in there so that could have been causing the hard/locking brake pedal, so i replaced both master and brake booster, new calipers, new rotors, new pads now, fresh fluid. let me just say if theres one thing on my car that is spectacular its my braking system. haha. i still have minor rattle but i think thats due to old wheel bearings and shot bushings.
which i have just havent had the time to down the car yet for those repairs.
Old 07-12-2012, 02:08 AM   #25
Might want to consider that engine wear is more expensive to fix than replacing brake pads more often. Not trying to start an argument over just how bad constant engine breaking is but the amount of friction required to slow a 3500-3600lbs (add occpant weight) mass isn't small.
Well, given everything you've replaced I sure hope the problem's gone... I'm even getting frustrated with it. I understand, crap pads are well, crap pads, but really even the worst pad should still provide consistent poor braking. lol
Crazy Electrical issue with EFI system Cameroonski MKIII Supra 10 08-16-2022 09:22 PM
Brake issue? sd88supra MKIII Supra 4 06-23-2011 08:59 AM
Brake issue! sawcut64 MKIII Supra 7 08-26-2010 09:37 PM
MKIII Wilwood 12.9" Rear Brakes With Parking Brake ARZ Arizona Performance 0 08-25-2010 06:34 PM
help with a brake issue tonystarks Non-Generation Specific Questions 3 05-21-2006 10:53 PM
