Old 06-13-2012, 05:41 AM   #1
Joefishizzle
Joefishizzle is on a distinguished road
Default Rear Main - W58 drop
Okay so my rear mains leaking pretty good, gotta do it. I have a 86.5 NA manual, can I just drop the tranny off the motor from underneath? I'd really rather not pull the whole motor if I don't have too..
Joefishizzle is offline   Reply With Quote
Old 06-13-2012, 05:59 AM   #2
You can but unless you have access to a lift and 10 feet of wobble socket extensions it's not really any easier... Not in my opinion.
Old 06-14-2012, 01:49 AM   #3
Joefishizzle
Well I know it's gonna be a bitch as it is, but Im wondering can it be done? Someone has to have some tricks with doing it lol
Old 06-14-2012, 04:06 AM   #4
Tricks.... Yup, a lift and about 10 extensions to reach the upper bell housing bolts. If I remember correctly, you'll need to loosen the motor mounts too and a transmission jack... Oh, and as always, drain it first. Getting it back in, with everything lined up and properly torqued is the best part.
I'm not really kidding about this. Without a lift it's utterly miserable.... with a lift it's well, only a little better.
Here's Toyota's instructions on it. Read through it thoroughly before you start.
http://www.cygnusx1.net/Supra/Librar...Section=MT&P=4
rear main seal leak questions?? Awyman18 MKIII Supra 2 01-08-2012 05:42 AM
Rear Speaker Replacement batmmannn MKIII Supra 0 06-07-2010 04:58 AM
Got rear ended. Repair or replace Any suggestions? BillW MKIII Supra 13 03-05-2010 04:29 AM
Rear Main Seal mkiiisupra MKIII Supra 3 09-28-2007 02:31 PM
