Old 06-10-2012, 06:23 AM   #1
akue
akue is on a distinguished road
Default supra has no electrical power
Hey first time on here but have a question I'm a delivery driver for pizza hut and I was on the way back from a delivery and as soon as I got back the car just shut off completly the only thing I can think of is the anti theft shut the car off I have issues with the secruity and it went off like 5 times within 3 hours the lights wernt dim or anything so right now I'm at a loss of what to do any ideas of getting it back up and running
akue is offline   Reply With Quote
Old 06-10-2012, 07:07 AM   #2
If you have no headlights or even dome light then check the 100A Fusible Link in the engine bay fuse box.... I think it's 100A, if not it's the highest value FL in that box.
Old 06-10-2012, 07:10 AM   #3
akue
See but I tried getting that fuse out and it wont come out at all
Old 06-10-2012, 04:49 PM   #4
akue
Ok so pulled the fuse and put a new one in still no power going threw the car is there a kill switch for the anti theft and the alarm. That's my problem the alarm disabled the car and I tried the locking the door and unlocking and unlocki.g it from the passanger side still nothing soo definitely at a loss have no clue what to do
Old 06-10-2012, 05:03 PM   #5
The factory alarm system only disables the starter. Do you absolutely no power to ANY circuit or does something, anything have power? Have you tested the battery thoroughly? Inspected the battery cables and grounds?
Old 06-10-2012, 05:12 PM   #6
akue
The battery full eveything looks good and I have no power to anything soo idk what's going on
Old 06-10-2012, 05:14 PM   #7
If the battery, cables and fusible link really are good you should have at least dome lights, hazards and headlights. If not then check again. Are you testing the battery with a proper load?
Old 06-10-2012, 05:16 PM   #8
akue
Ya I was driving when the car just shut off idk if a ground came undone or somthing blew
Old 06-10-2012, 05:21 PM   #9
The fusible link is the most likely issue, common problem. On some MKIII's it's just a special piece of wire and later models used the fuse like assembly (they're interchangeable). It's bolted in on the underside of the panel in the fuse box, you can;t just pull it out.... Did you replace the right thing?
Old 06-10-2012, 05:26 PM   #10
akue
Ya that's what I replaced
mk3 supra power steering fluid 2fast4u MKIII Supra 14 04-16-2012 01:29 PM
Supra slow to pick up power downunder MKIII Supra 7 03-02-2011 11:49 PM
94 Supra TT with idling and lost of power issue bayatt MKIV Supra 4 03-12-2010 01:29 PM
1991 Non-Turbo Supra - Power Antennae Replacement Options unkymurch Non-Generation Specific Questions 2 04-29-2007 06:35 PM
