Old 05-22-2012, 06:43 PM   #1
Joefishizzle
Joefishizzle is on a distinguished road
Default Code 21 again
Okay guys so originally, started with codes 21, 41, and 51......
replaced afm with new one, new oem Toyota tps and connector, and replaced with brand new Denso O2 sensor and gasket. I still get a code 21 while driving. My car only has one o2, its not a California car. Im not worried about smog I just don't want this damn code on anymore. My next step is checking the ecu, anyone have a pinout of the ecu? Also what type of reading am I looking for? (ohms, volts?)
Oh and if it helps, 86.5 NA 5 Speed....thanks guys
Joefishizzle is offline   Reply With Quote
Old 05-22-2012, 08:49 PM   #2
DawgB0
DawgB0 is on a distinguished road
You sure u have it connected n no short out or broken wire cuz dat exactly happened to me on my gte
92' 7mgte MT st8 bakcat
DawgB0 is offline   Reply With Quote
Old 05-23-2012, 01:35 PM   #3
Joefishizzle
Ya its connected correctly....does anyone know what I should be reading with a multi meter? Or where too test? oh and the code is intermittent.....doesn't happen all the time
Old 05-23-2012, 04:22 PM   #4
Green7mgte
Supra Forum Moderator
http://www.cygnusx1.net/Supra/Librar...spx?S=FI&P=119
o2 sensor..
and the 02 heater sensor
http://www.cygnusx1.net/Supra/Librar...spx?S=FI&P=121
since you said you just replaced your 02 sensor and all your wires are non corroded or dry rotted.. then id lean more towards the 02 heater sensor.
and 2 pages past that is.
http://www.cygnusx1.net/Supra/Librar...spx?S=FI&P=122
ecu stuff
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-23-2012, 05:45 PM   #5
The 7M-GE's o2 sensor does not have a heater, just the 7M-GTE.
Old 05-23-2012, 06:58 PM   #6
Green7mgte
Didn't see the n/a. I guess I just assume everyone owns a turbo.
Supra FAQ
Supra MKIII FAQ
Old 05-24-2012, 01:47 PM   #7
Joefishizzle
I wish I did have a turbo lol, and thanks I'll look at the resistance today. Like I said replaced a year old Denso sensor with a brand new Denso one. So idk, wire looks good. No breaks or corrosion.
Old 05-24-2012, 02:23 PM   #8
Joefishizzle
Also forgot to ask. Is there maybe a difference in connectors? Im running Denso #24-1051 as per what I looked up and according to autozones website. I see another option for 24-1057 but from what I've read that's a universal fit
How to check diagnostic codes suprra_girl MKIII FAQ 10 12-27-2011 08:30 PM
TPS code 41... Cyberguy1992 MKIII Supra 0 04-26-2011 08:14 PM
Damn code 51/31 Supra Saiyan MKIII Supra 10 02-15-2011 10:57 AM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
