Old 05-10-2012, 03:22 AM   #1
Awyman18
Awyman18 is on a distinguished road
Default MAF-T & Apexi AFC 5 KNOB
Ok so im about to buy a maf-t and i currently own a apexi afc 5 knob. Im going to throw in some 550cc injectors and obviously a walbro 255 fuel pump. I was told, i dont need a new fuel regulator, and i can use the stock one. Is that correct or no?
Also, how does the maf-t hook up? And should i use the apexi 5 knob with the maf-t? I heard the maf-t kinda hooks up to ur fmic piping?
Maf-t i heard is a decent device for tuning, and getting past fuel cut...which is wat i want to do...lol i want to run 15psi on stock ct-26 and thats it. Wat can u tell me about maf-t?? ive searched the forums here and found lots of stuff on maft-pro but not much on maf-t Also when i tune this, it will go to a professional. Any advice? lol
Awyman18 is offline   Reply With Quote
Old 05-10-2012, 04:00 AM   #2
I didn't re-read these but I'm pretty sure I covered the basics in at least one of them:
http://www.toyota-supra.info/forums/mkiii-supra/20429-karman-vortex-air-flow-meter-supra-turbo-lexus-compatibility-not-upgrade.html?highlight=maf-t
http://www.toyota-supra.info/forums/mkiii-faq/19847-maft-pro-or-something-newer-better-now.html?highlight=maf-t
http://www.toyota-supra.info/forums/mkiii-supra/15330-mass-air-flow-alternative.html?highlight=maf-t
The MAF-T is NOT a tuning device... That's why you have the SAFC. The MAF-T is only intended to allow you to convert to a GM MAF sensor with is available in larger sizes and thus offers less restriction (plus they're MUCH cheaper to replace, easier to find and just as reliable as your old KVAFM).
A NEW, STOCK fuel pressure regulator will be fine. The concern comes from running an old unit which isn't going to hold up to the extra flow. I haven't had a problem running stock FPRs and upgraded pumps. A healthy FPD is also needed.
Old 05-10-2012, 04:31 AM   #3
Awyman18
ive already read all of those cre lol they helped, but healthy FPD? fuel pressure detector..? lol but yea i keep hearing the MAF-T is a "rough" tune...so a crappy tune...doesnt sound good to me lol
Old 05-10-2012, 06:32 AM   #4
The MAF-T has trim potentiometers for low, mid and high signals inside of the unit. It's just for tweaking subtle offsets and it's resolution is poor. You are best off not considering it a tuning device of any sort... Keep the SAFC for that. If you must tune with the MAF-T's pots (for whatever reason), tune those first to set the mainscale and then tune with the SAFC.
The GM MAF will go in place of your KVAFM. You will need adapters to make it fit. I suspect a 3" MAF will fit the best. I think any larger is overkill for your application. The size of the MAF will affect your fuel cut.
FPD = Fuel Pulsation Damper. Basically it's a simple FPR used to reduce noise in the fuel rail... removes oscillations in fuel pressure which the FPR doesn't. It's on the backside of the fuel rail, looks like a FPR without the vacuum port, has a grey plastic cap and under that is just a tiny screw. DO NOT TOUCH THE SCREW!!!!!!!!!!! This is NOT a user serviceable part. A bad FPD will cause symptoms similar to a bad FPR.
Old 05-10-2012, 11:56 AM   #5
Green7mgte
Supra Forum Moderator
not to hijack. but since its along the same topic. Can you relay where I can find indepth info on open n close loop maps and how they work? I need to understand this. This information is pertinent to this topic also.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 05-10-2012, 01:39 PM   #6
Awyman18
awwww now we are on the same page cre..lol ok so, yea i plan on recirculating the bpv, so im going to put it where the kvafm goes (like u said) heard if i do this tho...i wont get that nice psshhhh sound tho? So get 3.5" piping and weld some bungs or watever on there to recirculate everything correct? Dont use my stock accordion pipe?
Old 05-10-2012, 05:22 PM   #7
turbonicsperformance
turbonicsperformance is on a distinguished road
you can use the stock acordian pipe if your going to recirculate your bpv. it will work exactly as if you still had a stock setup just with a maf instead of a kvafm
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 05-10-2012, 11:14 PM   #8
Awyman18
lol i probably could of just texted u and ask turbo....fail
Old 05-11-2012, 03:44 AM   #9
Awyman18
where exactly and wat exactly am i looking in a FPD?
tuning with apexi 5 knob AFC Awyman18 MKIII Supra 5 04-21-2012 09:21 AM
Apexi Power Intake for N/A MKIII OdysseusOnWheels MKIII Supra 5 06-10-2011 06:51 PM
How to tune Apexi Safc?? Conga1991 MKIII Supra 5 03-29-2011 01:44 AM
Removing shift knob Durandal MKIII Supra 2 11-07-2010 05:35 PM
ANY ONE EVERY USE A Apexi Boost Controller donutking MKIII Supra 1 10-07-2005 01:58 PM
