Old 02-06-2012, 09:18 PM   #11
newtosupra
newtosupra is on a distinguished road
alright will do ... cause somene PMed me and said it may be my ecu and i was thing it was something with grounding...but im still gonna check evrything people tell me to first before i go and buy a new ecu
newtosupra is offline   Reply With Quote
Old 02-06-2012, 09:39 PM   #12
The ECU is pretty solid. It's very often suggested as the cause of someone's problem but VERY rarely is that the case... I'm not saying you're not that one lucky person out of a hundred but until you've actually tested all the possible components you shouldn't be spending any money on it.... well, new spark plugs and wires are seldom a bad investment and they're cheap.
Old 02-06-2012, 09:42 PM   #13
newtosupra
Red face
alright another noob question under the hood of my supra theirs a little box looking thing that says diagnosis ... do u know what tool i use to actually use the diagnosis feature on the car ?
Old 02-06-2012, 10:01 PM   #14
So all this time you haven't even checked for diagnostic codes? I covered that in my FIRST reply to you.
And you mean "there's" as in "there is" not "theirs" as in "they" possessive with an "s" added for flavor. Sorry, the grammar thing just kills me.
Old 02-07-2012, 02:29 AM   #15
newtosupra
that wold be correct because i dont know how to clue how to check the diagnosis codes ... and sorry about the grammer i was on my phone
i'm just all around confused with the problem because as long as the car doesnt get frozen over in the morning it will keep spark and start right up
which is confusing because i didnt think spark should have anything to do with the temperature outside the car
Old 02-07-2012, 02:45 AM   #16
For the last time... Read the second post in this thread; Pay extra attention to the part that says to "look in the FAQ section for the info on 'how to check for diagnostic/error codes'".
...i didnt think spark should have anything to do with the temperature outside the car
Yes, temperature may affect how the car starts. Aside from the fact that the ECU operates the engine differently based on input from a couple different temperature sensors, an electrical short or break my be exacerbated by temperature. My first guess (not that I have been given any real info to go on) is that it's probably either the ECU coolant temp sensor, AFM, distributor or faulty wiring.
Good luck with it, I'm out.
Old 02-08-2012, 04:07 AM   #17
this forum is a great learning device, helps many with woes. but be willing to put in the work. check the MK3 faq for how to run dio
Tags
issue, spark
86.5 7MGE wont start , no spark Spitfire_Fox MKIII Supra 6 06-24-2011 03:25 PM
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
