Old 02-04-2012, 03:35 PM   #3
i ran a 5mge flywheel on my 7m a few years back, its pretty well the same, but the pressure plates are weaker on the 5mge. and yesw as cre said none of the gte products will work with a N/A.
also beware that the older w58s shifters are in a slightly different spot.
be sure to buy a brand new master and slave clutch cylinders as they are WORTH the money.
and dont forget to search the forum for 5 speed swaps there is LOTS of great info around here, just gotta search.
if i install an after market clutch do i need after market flywheel? alicethemk3 MKIII Supra 6 04-13-2011 07:16 PM
Partially Attach Flywheel go.stfu MKIII Supra 5 10-11-2007 03:06 PM
Who here is running a aluminium flywheel, or has run one? Chambers MKIII Supra 2 08-31-2007 06:33 PM
what clutch and flywheel setup?? boner1115 MKIII Supra 2 06-12-2007 04:53 AM
racing flywheel Jeff_5_7 MKIII Supra 7 02-14-2007 04:31 AM
