Old 01-13-2012, 11:35 PM   #1
rvaca
rvaca is on a distinguished road
Default 1989-water hose broke under dist cap, now wont start
replaced coil, igniter, & still no spark? Do I need to reset something or is there an inline fuse? Thank you in advance. RV
rvaca is offline   Reply With Quote
Old 01-14-2012, 10:45 PM   #2
Turbo or non? Which coolant hose? It's most likely an electrical issue unless it somehow managed to soak the timing belt causing it to slip. Where all did it spray? Does the car try to start at all? If you have an air filter that's open in the engine bay (a poor choice of placement) the air flow meter may have been damaged (more likely with the GTE's KVAFM than the GE's VAFM). The distributor/CPS may have gotten soaked as most coolant lines in that area run right under it.
1989 Supra will not start AlmostRunning MKIII Supra 7 12-22-2011 06:22 AM
1989 MKIII wont start subjated MKIII Supra 4 03-21-2011 10:41 PM
1989 non-turbo will not start Oceanside MKIII Supra 2 10-17-2010 08:14 PM
HELP: 1989 Supra WONT START! Sobo MKIII Supra 3 11-16-2008 12:20 AM
