Old 01-05-2012, 02:38 AM   #1
laturnus
laturnus is on a distinguished road
Default 7mge swapped 4runner help
i have a 1987 4runner with a 7mge swap out of a 89 supra. I have had several problems with the wiring in the truck because i obtained it from a close friend who in turn bought it from someone else who had no idea how to do automotive wiring. I finally got it running today with the E1 and T terminals jumped to do the timing. It was running perfect at 15*. I turned the truck off with the diagnostic jumper wire still in, when i tried to start the truck again it would not run. I pulled the diagnostic wire out and it started to run very rough like it wasn't timed again. While it was running poorly, i jumped the terminals, it revved very high then died suddenly. It starts with no jumper in and runs for about 5-10 seconds at what sounds like 400 rpm, but with the diagnostic jumper in it will not run. Someone please help.
thanks,
Mark
laturnus is offline   Reply With Quote
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
4runner 7MGE swap idle problem grabber MKIII Supra 3 06-26-2008 11:45 PM
2006 Toyota 4Runner silly Off Topic Forum 1 07-07-2006 06:52 PM
