Old 01-04-2012, 02:12 AM   #1
22, 24, 32, and 34 all have ECU on the list. make sure that when you swapped that engine in you grounded that ecu properly. just a thought...
Old 01-04-2012, 03:35 AM   #2
The GTE and GE use different tachometer drive circuits. You can convert from one to the other by replacing a few resistors on the PCB or just locate a GTE tach and swap it in. I've post the details on the modification here in the past, some searching should bring it up... it *might* be in the MKIII FAQ section.
Also of note is that you cannot properly set the ignition advance if there are any diagnostic codes present. Clear the codes, set the timing and then see if the hesitation/break-up is gone.
Old 01-04-2012, 02:19 PM   #3
2genfun
2genfun is on a distinguished road
ground the ecu where? theres only connectors to plug in and then screw it into the brackets?
88 targa. H&R springs, koni adustable shocks, 18" wheels, d&s rotors, goodrich brake lines, 7mgte in progress...
2genfun is offline   Reply With Quote
Old 01-04-2012, 05:12 PM   #4
No, not the chassis ground. Grounds E1 and E2. They're the grounds which connect to the free stud on the lower portion of the intake manifold. There's also a ground on the exhaust side of the head. Make sure they're all clean as possible (sandpaper recommended) and solidly bolted in place... clean the nuts' flange surface too (technically the nuts are single use only but cleaning them works fine).
Old 01-05-2012, 04:27 AM   #5
2genfun
figured it out...but now i only have one code... 11. and the check engine light goes on and off while driving. every once in a while the car bucks like its trying to die while accelerating...hmmmm
Old 01-05-2012, 05:03 AM   #6
Code 11 Momentary interruption in power supply to ECU (electronic control unit or computer) up to 1991
Go figure...
Purchasing and upgrade questions for a 1993-1996 supra non turbo slayer8925 MKIV Supra 9 04-29-2009 09:31 PM
87 turbo questions!! Reeves MKIII Supra 2 03-04-2006 12:36 AM
