Old 12-11-2011, 08:13 PM   #1
amebb
amebb is on a distinguished road
Default CPS out by 180 degrees
Just a quick question with my car.
The thing with my car is that i have set the crank shaft pulley to zero mark and made sure that it is on TDC.
Cam shafts are aligned to the mark on the back plates.
The CPS is aligned as describbed in the manuals BUT the car dosnt start very well.
BUT, if i then set the crank to zero and make sure its at TDC and then mark the cams to the markings etc ... AND Then put the CPS in to the head at 180 degrees out... the car starts OK..... and is fine.
Can anyone tell me how this would be and why is the CPS out by 180 degrees ??
The CPS and TPS are ALL working correctly. They have been checked and the values are within specified readings.
Thanks
amebb is offline   Reply With Quote
Old 12-11-2011, 08:29 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Just checking, do the cams look like this when the crank pulley is at zero ?
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
Oil loss in my red 7m na batmmannn MKIII Supra 26 07-17-2010 09:44 AM
sputtering 7mgte any help?! Androidrc MKIII Supra 16 01-03-2010 08:45 PM
Oil wieght for turbo motors Caliturbo88 Non-Generation Specific Questions 7 01-31-2007 04:21 AM
Standard /static Timing setting WilliamBodie MKIII Supra 6 12-08-2005 11:35 AM
