Old 12-06-2011, 02:30 AM   #1
Reaper6193
Reaper6193 is on a distinguished road
Default Gas Leak
I just completely replaced my heads and head gasket. I went to start it up and it started to leak gas from the gas line at the bottom of the engine. Any possible reason y it would be doing this? I have braided hoses to.
Reaper6193 is offline   Reply With Quote
Old 12-07-2011, 04:55 AM   #2
Could be running down from any number of places. Did you use new washers at all of the junctions? Did you replace injector O-rings and make damn sure not to pinch them when reinstalling them (it's VERY easy to do without noticing).
Old 12-07-2011, 07:30 PM   #3
Reaper6193
Well i jus got done replacing the hose and all the connectors. The hose was corroding and the adapters were striping. Now i'm replacing the copper o rings and hoping that will stop the leak....they were also corroding as well....if not i'm lost for words y it's leaking.
Oil Leak and extra Plugs?? Help?!?! Conga1991 MKIII Supra 10 02-08-2011 06:41 AM
Coolent hose leak. probably heater core Green7mgte MKIII Supra 7 11-26-2009 04:43 PM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
gas tank leak burton51m MKIII Supra 14 11-24-2006 06:16 PM
