Old 11-17-2011, 03:47 AM   #4
A weak battery isn't going to affect how the engine runs very much unless there's something significantly wrong with it. The alternator is what you need to look at if you think that's the issue.
BHG's can cause many different symptoms depending on where it's blown and how big the leaks are.
Did you read the old spark plugs before disposing of them? If not, do you still have them? If the problem is in or before the combustion chamber they'll give you a very good idea what problems you may be facing and in which cylinders.
Lots of white smoke IKneX MKIII Supra 18 07-16-2011 03:05 PM
white smoke while below 1500rpm and over heating spunkenhimer MKIII Supra 22 02-12-2011 06:04 AM
white and blue smoke after rebuilding head block ahruizguerra MKIII Supra 2 10-01-2010 07:50 PM
White smoke from exhaust manifold Rommy MKIII Supra 15 07-26-2009 06:32 PM
White Smoke Drag0na5h MKIII Supra 1 04-25-2006 06:36 AM
