Old 11-21-2011, 08:30 PM   #1
87hilux7mge
87hilux7mge's Avatar
true, but things like over tqing head bolts/studs, you can crack heads, strip threads, cause alot of headaches. 90ft lbs is waaaaaaay enough to keep stuff sealed if built and machined properly.
my first sbc only had like 65 ft lbs and that was on 5 bolts per cyl. (i say only and toyotas original specs were for 58 ft lbs. haha)
Re-torque head gasket from 56 ft./lb. to 75 ft./lb. (Good idea or bad idea) Randy0223 MKIII Supra 4 04-23-2011 09:50 PM
Head Gasket Part II Bullz_EyE MKIII Supra 2 01-26-2006 06:30 PM
