Old 10-01-2005, 11:40 PM   #1
87supraturbo
87supraturbo is on a distinguished road
Default Trouble starting?
Over the past couple of days my supra has had some troubles starting, ive got an 87 turbo and it will turn over for a long time then it will eventually catch and sounds like its going to die, then it will fire up and be fine for the rest of the day usually, its just starting it up cold that it doesnt like. any suggestions on what it could be or tests to do? something need replacing?
thanks
87supraturbo is offline   Reply With Quote
Old 10-02-2005, 04:03 AM   #2
supra887mgte
supra887mgte is on a distinguished road
Default coldstart plug
theres a little plug in the intake manifold that has a hose going to it its ur cold start plug take it out and clean it if u can hopefully its not shot or ull need a new one
supra887mgte is offline   Reply With Quote
Old 10-02-2005, 11:52 PM   #3
RNEMESiS42
RNEMESiS42's Avatar
RNEMESiS42 is on a distinguished road
I've got an 87 Supra and I've been having basically the same problem...it turns over, but it won't start. Sometimes if I let it sit for a few days it will start again. My spark plugs have never been replaced so I was thinking that might be the culprit...I could only get to about four of them, but the closest to the front of the engine was pretty gunked up. Cleaned them up and I tested them and they still spark...
You got a better description of what the cold start plug looks like? Or will I know it when I see it? I'll give it a try.
RNEMESiS42 is offline   Reply With Quote
Old 10-03-2005, 01:38 AM   #4
monkihead
SP58GT
monkihead's Avatar
i believe ya'll are talking about the cold start injector. on the 7mgte it is located on the upper intake plenum. if you stand by the driver side fender, in between intake runners 3 & 4 will be the cold start injector. it takes 2 screws, a single clip connector and has an attachment to the fuel rail.
monique- better off dead
1987 toyota supra trouble starting derekrd Non-Generation Specific Questions 3 12-09-2008 05:05 PM
cold starting problems Cjanik MKIII Supra 9 08-02-2008 06:50 PM
Trouble starting when engine is warm trevor217 MKIII Supra 4 12-23-2007 12:27 AM
starting motor Dom MKIV Supra 3 04-05-2007 01:57 PM
engine noise car dies after starting tex1116 MKIII Supra 7 11-18-2005 06:47 PM
