Old 10-15-2011, 04:33 AM   #11
You're going about it the right way... make sure it's all solid BEFORE trying to squeeze more out of it. I'm just making sure all the details are posted (both for yourself and for future readers). The zip ties are what you'll want to use on the vacuum hose.
Old 10-15-2011, 10:25 AM   #12
icey756
The only problem i have with the zip ties for the vacuum hoses is taking them off after if i want to make any changes. I would most likely have to cut them and then i would risk cutting the vacuum hoses as well. suggestions?
Old 10-17-2011, 07:51 PM   #13
Nah, as long as the edge of the nipple is still smooth (not corroded and rough) the vacuum line will still slide on and off, just with some extra tension. I've yet to have a silicone hose not just slide back on even with the zip tie on it... like I said the stuff is slick... in a bad way for this kind of application. Besides, you don't get a choice really; Do it now or do it later after getting pissed about numerous vacuum leaks.
Old 10-18-2011, 02:30 AM   #14
icey756
Thanks cre. I started today and will be finishing tomorrow. Girlfriend showed up and she didnt wanna sit there anymore and watch me work. Haha. When are they going to learn that sometimes there are more important things in life. Lol.
87 NA Coolant Line Diagram kurth MKIII Supra 6 10-14-2011 10:03 PM
capped metal coolant line????? twinturbolvr MKIII Supra 4 08-06-2008 04:32 AM
