#1 |
toyota went to a 2 peice because it reduced noise and vibration at higher speeds..
the reason why theres so much noise and vibration is because theres a driveshaft length limit until it starts to rotate alil more oblong then usual.. (drive shaft, 2 piece or not, rotate in a oval shape not a true circle) you have 68" around 60-68" you should switch to a 2 peice just to reduce vibration and have a lil more smoother drive.. sadly this takes away torque... there is no problem with a one peice tho
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP.. i really want turbo
| Thread | Thread Starter | Forum | Replies | Last Post |
| Manual to Auto, Killswitch, Drive shaft | wayzhack | MKIII Supra | 7 | 10-13-2010 02:35 AM |
| center bering for drive shaft good or bad? | carl johansson | MKIII Supra | 3 | 01-10-2010 05:31 AM |
| one piece drive shaft | mizuboi | MKIII Supra | 1 | 09-23-2006 03:35 PM |
