Old 08-29-2011, 02:10 PM   #1
Ranma
Ranma's Avatar
Talking the cure for some no starts
My battery was dead, so I jumped him and drove into Tulsa. A quick check and he started. Went inside shopped came back and tried to start, nothing. Lots of power but nothing. The man tried his battery nothing. So I remembered the security system, went outside the car and cycled the drivers side lock. Got back it the car and he started right up.
So perhaps a lot of no turn, no start issues are being caused by this?
Old 09-01-2011, 04:37 AM   #2
Yes, this is a common problem for many unfortunate owners... Fortunately you were well informed enough to try unlocking with a different door and didn't get the car towed to a dealership.
Old 09-01-2011, 08:02 AM   #3
87hilux7mge
87hilux7mge's Avatar
love when girls can figure out stuff on cars
man i see an article about the security systems every other day, they must have been a PITA..
i never remember mine having a problem, but then again i didnt own in for a real long time, and idk if it ever had a security system... sigh...
Old 09-02-2011, 12:15 AM   #4
Busted Knuckles
Busted Knuckles's Avatar
I've had problems with mine. The driver's side door occasionally will not disarm the alarm. I have to go around to the passenger side to turn off the alarm blaring away. This happens on the hottest of days when the sun shines on the door handle.
Another time, it went off on it's own while I was in the garage. No rhyme or reason, just started blaring. That only happened once.
Old 09-02-2011, 12:26 AM   #5
They weren't so bad when the parts were all new... but aging contacts screwed to the back of lock cylinders and magnetic reed switches for sensors which loosen from their mounts over time tend to make the system a source of contention for many people. The worn out switch on the driver's side lock cylinder is the cause of 95% of alarm related problems.. replace the switch and the owner's happy for another 15 years.
Old 09-02-2011, 03:13 PM   #6
Ranma
Ranma's Avatar
Talking
The Alarm did not go off, the car just refused to turn over. I was pondering having it towed when it hit me "Earth to Ranma, come in Ranma this is Earth. Might be the security system, try locking and unlocking the door." He fired right up! Think Cre is right, the drivers side door handle is fracked. Have been having trouble finding a new one.
engine starts to fire and stops dead in its tracks?? firing order? 89supra1990 MKIII Supra 1 01-14-2011 11:51 PM
Car starts then dies. Starts then won't start judodude64 MKIII Supra 2 08-20-2009 12:27 AM
86 supra MK11 engine starts but will not run bigtime337 MKII Supra 3 03-05-2009 04:03 AM
Starts then stalls instantly JDJS45 MKIII Supra 4 11-27-2008 03:26 PM
mkIII probs, starts then dies and then not at all katillidie MKIII Supra 3 03-30-2006 08:24 AM
