Old 09-27-2005, 04:35 AM   #1
s0ulstar
s0ulstar is on a distinguished road
Question jacked up fuel sensor!
ok...so i just bought my '86.5 MKIII last week...did some basic ish to clear my mind.. ((i.e. oil change..timing belt change..tires..etc))...because i bought it offa some dirty old man in hawthorne..pretty ghetto if you dont know...but anyway..just yesterday i filled up my tank ((mobil..91...$3.09/gallon!!)) and the needle moved up about 3/4 full nd stopped...nd now its jus down to 1/4...nd i know that i couldnt have used that much gas...i work a few blocks away from BOTH my jobs!!...
can somebody point me in the right direction...i really dont feel that comfortable working with the gas tank..any help??..suggestions??...anything??
s0ulstar is offline   Reply With Quote
Old 09-27-2005, 07:43 AM   #2
kewlcoconut
When you bought the car, was the guy that you bought it from using it daily? Or did he just have it sitting around?
I know when I got my supra, I didnt drive it for a long time. And when I finally did, my fuel would only go up to about half a tank when I know I filled it. It took some time for it to get working again. But yours could be a different story.
Old 09-27-2005, 09:42 AM   #3
first thing check your sensor is in the correct position in the tank
(unscrew the 3 screws in the plate in your trunk/boot)
it should be in this position
Old 09-27-2005, 01:51 PM   #4
s0ulstar
i think he just moved it every once and awhile...it was jus sitting....so...maybe....
but here it is:
Old 09-27-2005, 02:04 PM   #5
well looks to be in the right position.... you could unscrew it... pull it out and just wiggle the floater to max and min and see if it frees it up
while you're there you can see how much petrol is really in ur tank
Old 09-28-2005, 12:56 AM   #6
s0ulstar
thanks... ..but i think ill let it go for a week before i decide to mess with it..cause i dont really want to mess up the sensor...hopefully... that'll work...if not..then ill try unscrewing it nd stuff...
Old 09-28-2005, 05:49 AM   #7
joel w
joel w's Avatar
Cool
i had to remove mine from the tank and carefully scratch off the "varnish" on the wrapped wire that the sender rod rubs on for it to make contact, Its been working now for 2 yrs with no issues
550 injector & lexus air flow troubles o2 sensor? night-rider MKIII Supra 1 09-03-2007 08:52 AM
fuel cut defender turbo xs joel williams MKIII Supra 8 08-21-2005 09:22 PM
