Old 07-08-2011, 08:59 PM   #1
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
Default Intercooler setup Pic Request and Questions
Ok. So i just turned my 7mgte for the first time in 2 years. Just finished rebuilding my engine(again), and Im in the process of installing my aftermarket intercooler setup and Stock oil cooler. Oil cooler was cleaned out, and the aftermarket intercooler setup is giving me hell of problems. First... WHY THE F%CK would they route the intake like that. frigging japan... anyways, yeah. So im going to install a regular intercooler, and didnt really count on how im going to run the piping from the turbo to the driver side of the car to catch the intercooler inlet. And now the oil cooler placement is also bugging me. I just want to see how the supra gurros installed there intercooler and maybe even the blow off valve setup.
Should i swich the intercooler out to one that the inlet outlet side are both on the same side??
Thanks again
Carlos
Ive been looking around, and some people have really clean setups, but have had the bumpers on. Thanks. Ill be away for two weeks since im doing some training, but i want to be able to do the piping myself. If i cant figure it out, muffler shop time. Thanks again. Get ready to have the cleanest supra driving around in a few weeks!!
1989 supra turbo-
uh-60 blackhawk... My life
Semper_Fi is offline   Reply With Quote
Old 07-09-2011, 12:52 AM   #2
Semper_Fi
Semper_Fi's Avatar
Thanks again
Carlos
Bump! Come on, some one took pics of there setup while they installed it.
1989 supra turbo-
Old 07-10-2011, 03:38 AM   #3
El Supracabras
El Supracabras's Avatar
This was an "ebay" intercooler kit (actually cxracing). I tried with a few different pipes and couplers but always the same routing. Ignore that bov, it's gone now, it seemed like a good idea at the time. One pic shows the routing pretty clearly, this was during the mock up process, many things had to be moved around. It was also important to me that it fit behind the crash/impact bar as im not willing to give that up for a small ammount of power gain.
Glad you finally got your car running.
ID:	4050   Click image for larger version
ID:	4051   Click image for larger version
Old 07-25-2011, 01:41 PM   #4
Semper_Fi
Semper_Fi's Avatar
Thanks!!!! Just got home... So lets see if i can get this
1989 supra turbo-
Old 07-25-2011, 04:47 PM   #5
El Supracabras
http://cgi.ebay.com/ebaymotors/89-92...item27bbd268a4
This looks like a newer version of the one I bought 2 years ago. I bought directly from cxracings ebay store. I have had zero problems other than the piping for the pcv and vac lines don't line up with the bolt holes on the crossover pipe (3000 pipe replacement) and the intercooler itself is much heavier than the stock one. It also is NOT a direct bolt at all. I had to relocate my oil cooler, horns, coolant reservoir, steering cooler, make brackets (which I think are now included) and modify the hood latch support a little so it would clear the front crash bar.
Good luck, and don't you think it's time you put some pics of the beast up?
Old 07-26-2011, 07:11 PM   #6
Semper_Fi
Semper_Fi's Avatar
Im posting pics as soon as im done with the intercooler kit... but i can show progress so far. Shes kinda ruff. Thanks again BRO!!!!!!
Can i ask for one more. How does ur intake fit? Also my Intercooler outlets are located on east and west... so i gotta figure how to redo the piping...
1989 supra turbo-
Turbo upgrade questions. Slater MKIII Supra 6 10-22-2006 04:13 PM
