Old 07-08-2011, 09:01 PM   #1
87hilux7mge
87hilux7mge's Avatar
i would say try a breaker bar to turn the motor over. if you did that and couldnt get it to turn over, prolly siezed :/
dragging with the car in gear doesnt always work.
you can always hotwire the starter to turn things over.
the green plug im trying to remember what it goes too. could you post a pic of it?
Old 07-08-2011, 09:12 PM   #2
87supra7mgte
idk what the green plug could go to, i know thats not the one for the starter, the one for the starter will have a female end for a connector that goes into the side of the starter kinda on the back towards the passenger side IIRC, i spotted the connector with a mirror and had a hard time gettin the wire plugged into it
Old 07-08-2011, 09:21 PM   #3
Anushamoon91
Anushamoon91 is on a distinguished road
Well tried the breaker bar and nothing. Gonna try to use some diesel to soak through to see if can break it loose. Yeah the plug I guess from what a friend told me earlier is that it goes from behind the starter to the transmission. He said it really doesn't need to be plugged in but in my opinion it is there for a reason. What that is I have yet to find out. Any good advise to try to breaking the motor loose?
Anushamoon91 is offline   Reply With Quote
Old 07-10-2011, 12:26 PM   #4
El Supracabras
El Supracabras's Avatar
If its a non turbo, you could try taking out the distributor and turning it. I actually had this happen to me, the distributor seized in an 86.5 n/a and the engine would not crank.
If you cant turn the engine with a breaker bar, I'd bet that it is seized. You can try diesel but chances are it's gonna be hurt even if it frees up. It aint no Chevy! If you were planning an engine build, now would be a great time.
EDIT- Also had this happen (on a camaro). It turned out that a couple mice had chewed through my air filter, crawled in through the intake all the way into the cylinders and completely filled a couple cylinders with corn kernels. Where the hell they got all that corn, I still dont know (I live in Chicago!). They had quite a stash in there, enough to prevent the engine from turning. When I started pulling the spark plugs, corn was pouring out of the holes. They had also chewed through a bunch of wiring under the hood. The car was only sitting for a year.
Old 07-10-2011, 06:01 PM   #5
87hilux7mge
damn rodents. always messin stuff up
87 non turbo wont start, need some advice...please. HotRodV6 MKIII Supra 3 09-02-2010 07:29 AM
changed turbo and now the car wont start venomstreetmachine MKIII Supra 12 08-26-2009 12:45 AM
