Old 05-30-2011, 02:42 AM   #1
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
Default No spark or fuel
Just finished rebuilding the 7mgte. I havent been able to get the fuel and spark problem resolved yet. So im turning for help from the supra forum. I baught a brand new ecu and new wire harness, new cps, and new ignitor. Im somehow not getting power to the fuse box, and wen I do manage by jumping the fusrbox, the car still doesnt get fuel or spark. Can I get help. Thanks supra forum. Carlos
Ps... Were is the fmi???
Excuse my short, shitty post. Im on my cell and my english is shitty. Thanks again.
1989 supra turbo-
uh-60 blackhawk... My life
Semper_Fi is offline   Reply With Quote
Old 05-30-2011, 12:05 PM   #2
El Supracabras
El Supracabras's Avatar
Holy gazillion dollars!! I don't even want to know how much all those NEW parts set you back.
Which fuse box are you talking about? The one under the hood is fed directly from the battery positive terminal by an 8 gauge(ish) wire. Does anything in that fuse box have 12V at all? Ive had to repair this wire on several old supras due to corrosion, accidents, mechanics who poorly replace the battery terminal, terrible wiring repairs,etc.
When you say no fuel, do you mean no pump operation or no injector pulse?
Old 05-30-2011, 06:32 PM   #3
Semper_Fi
Semper_Fi's Avatar
Im not getting any fuel when I try to crank the car, I pull the spark plugs after each failed atempt to turn on, and I dont smell any fuel on plugs. And wen I pull the plug and crANK the car, I pull the plug out,and ground it and no spark... 500 dollars more into this car and ima have to cut my losses. The car is scheduled for a body shop, and a 700$ cf hood. I really hope I can,have her running. Please help
1989 supra turbo-
Old 05-30-2011, 08:38 PM   #4
El Supracabras
I assume you've made sure the supply wire to the fuse box is in excellent condition. Have you double checked all your grounds? The two under the intake by the brake booster are very important for the ecu. Do you have fuel pressure?? You need to figure out if the fuel pump is not turning on or if the ecu is not firing the injectors. This will tell you where to look next. Check the cps wiring again. It gives information to the ecu for both spark and fuel. Use the tsrm diagram for reference if you need to. You need a multimeter or at least test lamp to trace power to and from the main relay, ecu, etc. etc... It shouldn't cost you any money to figure out whats not working, just time and patience... and a multimeter. Good luck.
Old 05-30-2011, 09:53 PM   #5
Semper_Fi
Semper_Fi's Avatar
Wow... How did I overlook the 2 grounds under the intake manifold. Hey man. I really could use as much as possible with the car. This supra is more complicated then the blackhawks I worked on daily for the past 6 months. My number is 4073509099. If u could text me so I could get more help I would be very thankful. Thanks again. Carlos
1989 supra turbo-
Old 06-01-2011, 07:31 PM   #6
Semper_Fi
Semper_Fi's Avatar
Bump!!! I need help with this car... My halfcage, seats, and steering wheel came in
1989 supra turbo-
Old 06-01-2011, 08:56 PM   #7
El Supracabras
I'd prefer to keep this on the forum for the benefit of others who may run into your problem.
What have you checked so far? Did connecting the grounds change anything? Do you have a multimeter? I need answers and actual measurements. Its impossible to start this car via a keyboard and screen without some important information. Here fill this out:
Stored codes:
Battery voltage:
Voltage at main relay:
Voltage at EFI fuse:
Voltage at EACH ecu power supply:
Ohm reading of ecu ground to chassis.
Condition of ALL grounds related to the ecu including coil pack ground wire:
Position of the timing marks on all of the gears and the cam sensor:
Fuel pressure:
When you crank the engine with a test lamp between the battery positive terminal and the ground wire of any injector clip does it flash? Does it stay on? Nothing at all?:
There's your homework, the wiring diagrams and procedures are all over the internet and this forum if you need them as well as the tsrm, report back with these answers and we can go from there. Don't stress and don't skip any steps, it sounds like you're putting a lot of money into it. Take your time, be thorough in measuring everything and you will no doubt get it running again.
Old 06-05-2011, 01:07 PM   #8
El Supracabras
Been a few days, any progress here? I'm interested in seeing your car finished. It seems like it is going to be very nice with all those new parts.
Old 06-07-2011, 08:04 AM   #9
Semper_Fi
Semper_Fi's Avatar
Sorry i have not been able to get online to give updates. I found a supra specialist. Really happy from his his price to get the car running completely. Pretty much, i was missing a hak sensor. that fixed the spark problem. The headlight issue however is what is bugging him. he thinks its the alternator...i will try my best to keep eveyone updated. hes going to make me a list so i can post it and show the forum why the car was not running.
1989 supra turbo-
Old 06-07-2011, 10:55 PM   #10
90supra7mgte
90supra7mgte's Avatar
90supra7mgte is on a distinguished road
yoo wat good ,did u ask ur boy about the problem am having on mines???
90supra7mgte is offline   Reply With Quote
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
car cranks, but no fuel or spark mustangtw5901 MKIII Supra 17 04-30-2008 07:48 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
