Old 05-06-2011, 11:57 PM   #1
mkiiisupra
Default Timing Belt
Brand new Gate's racing timing belt.
10 miles down the road car dies.
Find out later that the timing belt got 4-5 teeth ripped off it, stoped spinning the cams and so the CPS stoped giving the signal to the ECU and basically told my car to kill everything... Good thing too lol
Now what cuases this? Manufacturer defect? The belt still had the right amount of tension on it.
Crank basically new, rebalanced etc, new ATI Dampner and new titan motorsport adjustible cam gears with BC 272 cams... on a fresh rebuild. Also new tensioner
1990 Toyota Supra Turbo A/T
Old 05-07-2011, 12:01 AM   #2
mkiiisupra
By the way, so far seems like this cuased no damage internally
Crank spins freely does not appear to have touched a valve. Hopefully everything is still straight
Old 05-07-2011, 12:25 AM   #3
87hilux7mge
87hilux7mge's Avatar
id say manufacture defect or a lil too much tension...the only other thing would be if the cam stopped and the crank spun the belt over.
show some pics if you can, might shed some light depending on how the damage appears.
Old 05-07-2011, 12:30 AM   #4
mkiiisupra
Ill get some pics up soon as i can. Both cams still spin freely as well as the crank
Old 05-07-2011, 12:33 AM   #5
907mge
907mge's Avatar
Yes I would agree on making sure the cam gears spin freely . But there should not be any problems since It should be a non-interferance motor.
Old 05-07-2011, 12:39 AM   #6
87hilux7mge
yea it shouldnt have had any piston to valve contact. but if a cam siezed then thats a bummer. especially with those nice, spendy 272's...
Old 05-07-2011, 02:09 AM   #7
mkiiisupra
I guess thats what u get when you buy high quality parts brand new and cut no corners...
Basically exhaust cam is the culprit to this issue... Oil is getting to the intake side great but on exhuast side it stops way SHORT. Possible a blockage of some kind inside the cam or just wasnt drilled all the way thru.
Old 05-07-2011, 03:35 AM   #8
907mge
907mge's Avatar
Well hopefully the head is not too damaged and you only need a new camshaft.
Old 05-07-2011, 07:03 PM   #9
87hilux7mge
damn...worst fear. thats a bummer man. hopefully you can get them to replace it for free, maybe the gates belt too :/
Timing belt install superwhite MKIII Supra 4 02-02-2011 07:09 AM
Timing belt questions..... Legionnaire MKIII Supra 0 09-17-2009 09:40 AM
New Timing Belt Direction Paul_NJ MKIII Supra 2 04-11-2009 01:16 AM
Replacing Timing belt Paul_NJ MKIII Supra 5 03-21-2009 05:35 PM
Photos of my timing belt Nato99 MKIII Supra 7 08-27-2007 09:33 PM
