Old 04-26-2011, 02:06 AM   #1
Daluz
Daluz is on a distinguished road
Default problems starting
i have an 87 base mode and when ever i go to start it, it always seems to be so close to starting but wont turn over the last little bit. what could this be?
Daluz is offline   Reply With Quote
Old 04-26-2011, 11:06 PM   #2
Cyberguy1992
Cyberguy1992's Avatar
Cyberguy1992 is on a distinguished road
Sounds like something simple with the Mass Air flow Sensor or a problem with the signal from the cam or distributor
1. Check your Mass Air Flow Sensor.. Make sure its still clamped on tightly
2. Check outputs from the Mass Air Flow Sensor KS(GTE), VS(GE), THA(GTE+GE)
3. Check outputs from cam sensor or distributor
OR
Short TE1 and E1 to read the codes, there should be one.
This will tell you how to read and interpret the codes
Around page 30
http://www.turboninjas.com/mk3supra/...-EFISystem.pdf
Cyberguy1992 is offline   Reply With Quote
Old 04-27-2011, 01:04 AM   #3
Daluz
Thank you, i changed out my maf, i think there might be a problem with my fuel filter because it was sitting for a while before i bought it, and when im trying to start it i can smell gas like pooling
Old 04-27-2011, 01:40 AM   #4
Cyberguy1992
Default no spark
If you smell gas that means are getting fuel and no spark... I'd look into your distributor or Cam sensor which ever one you have
Old 04-27-2011, 01:46 AM   #5
Daluz
Ahhh alright thanks
Unreliable starting. (Problems starting) Hiccups MKIII Supra 9 06-01-2012 05:33 PM
Starting Problems turbo jim MKIII Supra 7 03-30-2009 07:09 PM
cold starting problems Cjanik MKIII Supra 9 08-02-2008 06:50 PM
Starting problems HELP adellicson MKIII Supra 0 05-08-2006 03:42 AM
