Old 04-24-2011, 08:05 PM   #1
subjated
subjated is on a distinguished road
Default White smoke/air intake problem?
As some of you may know i have a 1989 markIII supra that wouldnt start, after a lot of head scratching and swearing i finally managed to get it started! turned out just to be a broken earth cable! any way it starts first time all the time and sounds lovely, but the is a lot of white smoke from the exhuast when starting, and really stinks of petrol so im immediatly thinking its running rich, so pointing towards some sort of air intake problem, but am i right to be thinking this? as anyone else had this sort of problem? or know what it could be? fingers crossed its not as bad as valve guides!
many thanks in advance
subjated is offline   Reply With Quote
Old 04-24-2011, 08:38 PM   #2
Cyberguy1992
Cyberguy1992's Avatar
Cyberguy1992 is on a distinguished road
I would look into adjusting the timing...
Warm it up... Short E and T @ the Check connector... Put trans in neutral... get the timing light out... line er up @10.. lock it down... maybe that will help....
That's where I would start
Cyberguy1992 is offline   Reply With Quote
Old 04-25-2011, 08:16 PM   #3
subjated
thanks for your reply, could you elaborate a little please, not quite sure i got that! also what do i do if the timing is out?
Old 05-12-2011, 07:20 AM   #4
Cyberguy1992
just make sure your ignition timing is set correctly.. Also check if you have oil around the spark plugs if you do then u probably need to replace your valve stem seals... Its not hard just time consuming and a bit tedious..
Old 05-12-2011, 08:38 PM   #5
subjated
Thanks for your reply ill check the plugs, how do I go about checking and or setting the timing? Ain't done that before! Cheers
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
another heater problem nicnet MKIII Supra 16 12-05-2007 10:18 PM
intake manifold has coolant what did i do wrong? 91toy supra MKIII Supra 6 09-16-2006 02:46 PM
