Old 04-15-2011, 10:23 PM   #1
dannydavi
dannydavi's Avatar
Default Overheating/coolant loss on long trips
Hey guys let me break it down for you.
I have an 86.5 Supra n/a automatic. It currently has JDM engine in it as I replaced the old one after it seized up on me.
As of a couple months ago I've had to periodically replace coolant with no visual signs of loss. The more I drive it, the more I notice it mostly occurs when going over mountains up hills etc on long trips. I thought BHG already?!?! and looked for milky solution under oil cap, dipstick and during oil changes and everything was good there. I did a compression check and it was perfect (200-202 psi all cylinders on warm engine), also no white smoke out of tailpipe so I set my attention at other probable causes.
Before my next two hour trip I bypassed my heater core all together, no more hoses going in or out of the firewall. The reason I did this is because my heater would sometimes out of the middle of nowhere start blowing cold air... even though it was just blowing hot and I am still on the same trip yada yada... so I bypassed it just to make sure it wasn't the cause, and that next trip proved it wasn't, overheated again as soon as I hit a hill. I let it cool down then I took the thermostat out and put more water in and it got me the rest of the way.
Next week I had to come home and it overheated again. So bypassed heater, removed thermo, did common BHG checks, and replaced radiator cap to no avail, any suggestions would be greatly appreciated guys. Feel free to ask as many questions as possible.
NOTE: It was overheating around town at one point as well and that's why I replaced the radiator cap cause I heard air and saw water coming out of there. So no more around town over heating but still mountain/long trip overheating. Also the coolant loss might just be from the coolant overflow after it is running hot... cause I'm not sure where it is going.
EDIT: NOTE: Also think it might be important to know that my temp gauge would raise up slowly then plummet back down to normal several times in a row before it would get hot and stay hot.
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-15-2011, 11:08 PM   #2
btwilson86
Super Moderator
btwilson86's Avatar
The temp gauge fluctuating and the heater changing from hot to cold sounds like you have air in the cooling system (which makes sense if it's been purging coolant).
After it overheats, is there any hot or cold spots in the cooling system? For example, is the upper hose hotter than the lower hose? One side of the radiator hotter than the other?
A possibility is that there may be some sort of blockage restricting the flow of coolant, causing it to overheat
Old 04-15-2011, 11:31 PM   #3
dannydavi
dannydavi's Avatar
I will hand check multiple places next time it occurs, I don't have a temp gauge that I can use to test it. Also I will try to see if the rad is blocked up at all... Any good ways to test that? I will try taking both hoses off of rad and full pressure garden hosing in the top and see if it backs up at all...
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Old 04-16-2011, 08:37 AM   #4
87hilux7mge
87hilux7mge's Avatar
if the rad is original, might be a good idea to look for a new one. to purge the system of air, put the front of the car on jack stands, high as you can get em safely. then take the cap off the rad, and start the car. make sure the coolant is circulating, and while it is doing so, top off the rad. it may take a few mins as the car will warm up and open the thermostat. to help the process along, squeeze the lower and upper rad hoses and heater hoses periodically.
another thing you can do it replace your thermostat. if its a stock on, get a new one, as it may be malfunctioning. also check if you fan is working properly, you could have a slipping clutch. this would not attribute to you losing coolant, but might have to do with your temp fluctuations.
Old 04-19-2011, 05:15 AM   #5
You are aware that 200+psi is WAYYY too high.... right? The N/A is supposed to be mid 150's.
Old 04-19-2011, 07:00 AM   #6
87hilux7mge
cre, ive been curious about this too. the two motors i picked up for my project (88 jdm 7mge, 90 cressida 7mge) both tested high compression while cold! the jdm motor ranged 185-193, the cressida ranged 20-195 (3 cyls were completely boned). when i disassembled the motors, they both had the same type of pistons, but when i compared them to my new pistons, they had considerably less dish in them, almost flat tops. i was concerned that id gotten turbo pistons, but compared them with my freind john's pistons, and mine were definitely for N/A. so somewhere, toyota got a wild hair up their bum and put high compression n/a pistons in some motors.
i had no luck finding these pistons anywhere.. but that seems to be in the same compression range as mine, since his was warm.
sorry that was a lil off topic...
Old 04-22-2011, 08:33 PM   #7
dannydavi
dannydavi's Avatar
I thought it was supposed to be 185ish... what does it mean if the compression is higher than it's supposed to be?
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
Oil loss in my red 7m na batmmannn MKIII Supra 26 07-17-2010 09:44 AM
Engine takes way too long to start GL4CI3R MKII Supra 1 07-17-2009 04:37 PM
Max safe long straight performance in a road race? Humba MKIV Supra 7 12-25-2008 05:38 AM
13th ALL TOYOTAFEST - New Venue in Long Beach, CA! toyotaco Off Topic Forum 0 03-23-2008 11:10 PM
Massive power loss 808Supra MKIII Supra 3 05-24-2006 02:58 AM
