#1 |
How many miles?
One thing I can tell you is the steering wheel is from a celica/matrix/corrolla. Which probably means if it even has an air bag in it, it will not work since I think 90 was the first year for a airbag. Looks like stock ride height. Oem type exhaust. From the picture of the hood it looks like the gaps are not even from side to side. So possible accident and repaint. Also it shows it does have TEMS(adjustable suspension) on the dash but the acuators under the hood are not there. They should be on the top of each strut. Missing molding on drivers side door atleast. If I where you I would also get a carfax to verify the milage. Last edited by 907mge; 04-09-2011 at 04:56 PM. |
#2 |
Supra Forum Moderator
good eye 907
Its also an NA so the exhaust change dosnt really mean anything. as for a new tranny, clutch, alternator I guess thats a +. If you think you look good in it and it proves to be reliable then hell why not. Try to talk him down more tho =-) I personally wouldn't spend any money on a 7mge but I'm an elitist jerk. Altho If I did need a car asap and that was available I would pick it up with the hopes of dropping a 7mgte in it eventually.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : Last edited by Green7mgte; 04-09-2011 at 06:35 PM. |
Thread Tools | |
Display Modes | |
Opinions on my dispute needed | Kevin | Off Topic Forum | 4 | 09-10-2009 01:36 AM |
Money to spend...upgrade path opinions. Put in your .02 cents! | godgaveussid | MKIII Supra | 10 | 11-25-2007 01:39 AM |
