Old 04-13-2011, 07:24 AM   #11
dine52
dine52 is on a distinguished road
Is the ecm suppose to supply the IGF wire w/ a full time volage and look for a ground interruption when it gets fire?
dine52 is offline   Reply With Quote
Old 04-14-2011, 02:15 AM   #12
Travis89Turbo
Travis89Turbo's Avatar
No, based off of my research it is normal to see 5v output from the ecu to igniter. But the igniter internally varies the resistance that the ecu translate into confirmation that the spark that it sent a signal out of the igt actually occurred. The only way to verify this is with a o-scope. Which basically shows a graph of the voltage variance! There is not a DMM on the market anywhere near fast enough to pick up the crazy small voltage variance!
But on a good note........... SHE IS ALIVE! I got the new ecu put in and it fired right up and runs like a champ again! Damn POS 1j ecus. This way I can save up for the new AEM standalone for the 1j driftmotion Jus got! Cause I kno this ecu will also fail eventually! Thanks for your help guys!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Damn code 51/31 Supra Saiyan MKIII Supra 10 02-15-2011 10:57 AM
Well... Another code.. Cyto MKIII Supra 1 02-02-2010 12:21 AM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
No Signal to Fuel Injector ithinkitwassumthini8 MKIII Supra 3 09-12-2006 06:35 AM
