Old 03-29-2011, 04:56 PM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
Default 7mgte cooling question
alright so i just got finished rebuilding my gte and im now in the process of doign my swap (7m into 92 miata) I will be deleting the heater anyway so i was wondering if i plug the banjo fitting in the back of the head and bypass all the little coolant lines on the side of the block if it will actually effect anything or not... Just think it would look ALOT cleaner without them as well as make this alot easier because i have very little space to actually bypass the banjo bolt in the head without cutting into my firewall
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 03-29-2011, 07:05 PM   #2
Travis89Turbo
Travis89Turbo's Avatar
Do not block off those lines. Your gonna have to Jus loop them the cooling system on the m series are far from forgiving. They are notorious for overheating
But sounds like a cool swap. Where's the pics?
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
Old 03-29-2011, 09:56 PM   #3
ill post some later when i upload them does anyone have a diagram or pics of how i have to route these to avoid my heater i get that i can just loop the banjo fitting but what do i do with the rest of the lines going all over the place im gonna run a dry intake anyway and delete isc so it seems like those metal lines would be useless also im gonna have ALOT more airflow over my radiator and believe it or not the engine bay is a little more open than the supras ?
Question regarding a 90 7MGTE Grandavi MKIII Supra 3 06-25-2010 05:42 AM
Question About 7mgte Rebuilt skadaloz MKIII Supra 3 08-15-2008 11:14 AM
Retorque 7mge & 7mgte question SilenceboneSupra MKIII Supra 2 01-30-2008 10:17 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
The 7mGTE and the Tranny question panda-supra MKII Supra 5 10-10-2006 02:25 AM
