#1 |
![]() Toyota Racing Development Join Date: Apr 2007
If it's bogging under ~4KRPM then check all the vacuum plumbing under the intake plenum. A problem with the ACIS system will cause sluggishness at lower RPM.
Yes, 10?BTDC with the diagnostic jumper in place.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#2 |
supracabra, did you set the cam position sensor back to where it needs to be when the motor is TDC before you installed it? Sounds like something simple that your missing. You don't need to jumper anything to check timing, just hook up timing light to #6 plug and see if it is running at 10 before TDC
#3 |
You're wrong... On both counts. You can only use #6 on the GTE for timing as it runs a wasted spark setup, not so on the GE; You MUST have the engine at normal operating temperatures, no critical diagnostic codes present, and you must jumper TE1 and E1 so the ECU does not adjust the ignition timing and sticks to the programmed map explicitly.
| Thread | Thread Starter | Forum | Replies | Last Post |
| Best Cylinder Head Seal | Supra Saiyan | MKIII Supra | 5 | 02-06-2011 01:10 AM |
| torque settings for big end shells and cylinder head | johnkarl | MKIII Supra | 4 | 11-03-2006 04:01 PM |
| Cylinder Head?? | ZauggIt1 | MKIII Supra | 8 | 10-24-2006 01:51 AM |
| Valve Job On Head Now Car Wont Start? | MKIII shujin | MKIII Supra | 4 | 08-07-2006 02:16 AM |
