Old 03-31-2011, 01:49 AM   #2
My88isGREAT
My88isGREAT's Avatar
My88isGREAT is on a distinguished road
supracabra, did you set the cam position sensor back to where it needs to be when the motor is TDC before you installed it? Sounds like something simple that your missing. You don't need to jumper anything to check timing, just hook up timing light to #6 plug and see if it is running at 10 before TDC
My88isGREAT is offline   Reply With Quote
