Old 03-08-2011, 04:48 PM   #1
johnvin
johnvin is on a distinguished road
Default 7mge to 7mte ?
im i able to swap out the non turbo engein to the turbo ? it a 1988 , or would i have to get a turbo model wire harness
johnvin is offline   Reply With Quote
Old 03-08-2011, 11:23 PM   #2
graywolf1969
graywolf1969 is on a distinguished road
Default hey
i did a jdm 7mgte swap to a usa 7mgte bc my engine was makeing noise from the top hafe and it died i had to swap the wireharness so it would work i think u do also your going to need the ecu too there ppl on here that can help u i think u have to but i could be rong
graywolf1969 is offline   Reply With Quote
Old 03-09-2011, 05:05 PM   #3
johnvin
ok thanks for the help bro !
Old 03-09-2011, 06:37 PM   #4
supraluver4life
supraluver4life is on a distinguished road
Wow you guys really need to learn how to type.
If you swap to a 7mgte you will need all the components of the engine like the coil packs, engine harness, ecu, afm, ignitor, etc.... Also depending on if you get the tranny with it (r154) you will need the pull type clutch, flywheel, pressure plate, and a new slave cylinder.
I have like three 7mgte's im parting out so let me know if your in need of anything and I'll see if i can help you out
Cusco front, Tein Rear coilovers
Massive DDP, 3'' custom catless exhaust, Tsudo muffler 4.5'' outlet, Apexi cold air intake, Act stage 3 clutch, ct26 turbo (stock)- 10psi
+300rwhp
"Not driving a car because its too nice, is like not fucking your gf so shes still tight for the next guy"
supraluver4life is offline   Reply With Quote
7MGE Build PaintballFTW MKIII Supra 6 02-20-2012 06:06 PM
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
7mgte to 7mge conversion help wayzhack MKIII Supra 7 09-07-2010 08:22 PM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
