Old 03-10-2011, 06:18 PM   #21
If not thought out too well, you may want to mix this with the vaseline or KY.
Old 03-23-2011, 01:47 PM   #22
gloreboy89
gloreboy89's Avatar
gloreboy89 is on a distinguished road
Default thanks guys
Thank you everyone who has helped me. I made a decision to stick with keeping the car and buying the 1jzte engine for $2800(the engine cost $1700). It come with another auto tranny so its complete i will also get new belts and i think i need a new water pump, for safety? idk should i change out the water pump?
Also what should i need to "freshen up" on this engine and transmission im getting?
I will be selling parts out of the old engine like the alternator and that engine harness.
too lazy to find a funny quote, buuuutttt off the top of my head. "life always= how well you treat your car, put crap in ur car, then car breaks down, then miss important meeting, or work which just so happen u cant miss another day or ur fired... and end up with a crappy life.
driving an '88 supra
gloreboy89 is offline   Reply With Quote
Old 03-23-2011, 03:20 PM   #23
Ranma
Ranma's Avatar
While you are changing the water pump might as well change the timing belt.
It never ends *grins*
Old 03-23-2011, 04:49 PM   #24
gloreboy89
gloreboy89's Avatar
yeah thats what i meant by "belts" but thats ok. I sthere anything else i should change out? also what oil should i use?
Old 04-05-2011, 05:27 AM   #25
gloreboy89
gloreboy89's Avatar
Default ok here's the hole in the old engine
this is on the driverside right under the starter
Old 04-05-2011, 04:44 PM   #26
btwilson86
Super Moderator
btwilson86's Avatar
Ha, nice... I put two holes like that in my first Supras' engine. Broke the no. 5 connecting rod, part went straight through the block in the no. 5 cylinder, the other part bounced around in the oil pan then went out on the other side through the block on the no. 6 cylinder
Old 04-05-2011, 05:18 PM   #27
Ranma
Ranma's Avatar
Talking
How did you manage to do this feat?
Old 04-06-2011, 03:57 AM   #28
Green7mgte
Supra Forum Moderator
hes just lucky.
LOL you sure are an advocate for water pump / timing belt combo Ranma. heh, better safe then sorry. oh and the numbing agent mixed with the lube.. now thats pro! (takes down notes)
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 04-06-2011, 05:01 AM   #29
btwilson86
Super Moderator
btwilson86's Avatar
hes just lucky.
Yeah, luck..... We'll go with that
Old 04-13-2011, 08:55 PM   #30
87hilux7mge
87hilux7mge's Avatar
^^PRICELESS!
so, ima chime in here. the jz series engines are great, but to put one in your mk3 (or any chassis that didnt have one stock) is going to be spendy and cause more down time, especially if you arent doing the conversion yourself.
the m series motors are great reliable engines, and most of the generic problems can be fixed simply.
1-BHG. if you buy a used engine and dont need to rebuild (always recommended), retorque the head bolts to 72 lb ft (dont loosen first!).
2- oil pressure. stock is sposed to me 4.3 psi at idle (scary!). easiest thing to do is throw about 5mm of washers in the pressure relief spring, ups ur psi decently (my freinds john sees about 12 psi on his buggy with this mod).
3- rod bolts. the stock rod bolts are good but if you drive hard, they will fail. upgrading to the ARP rod bolts is cheap, easy and totally effective. ur rods will have to be resized after u install the bolts (my machine shop charges 7 bux a rod, whoopie).
really thats it, they are simple, reliable and incredibly durable. toyota blocks and cranks are incredibly stout, id say stock block, rods and crank can prolly surpass 700 hp.
Tags
engine problems
Help on deciding which type of engine x1KraZyDriVeR MKIV FAQ 5 03-23-2008 08:54 PM
