Old 02-26-2011, 08:01 AM   #1
ochowdero
Default Transmission rant, help! Need advice or anything, asap
well recently, i went to go change my transmission fluid,
did all the work to change it. drove it home and about an hour later there was transmission fluid all over the ground..
so immediately i squeeazed my way under the car and found out that a bolt broke off and 2 bolts were loose. my bad right? didnt check them all close enough
the next day i take it back to the shop and put it on the hoist, the mechanic told me that i need to tap it out. (i told him i should reverse tap it cuz it would be easier, and he said no it wont work....so i didnt argue and just did it his way)
so i started drilling into the bolt so i can tap it out, the mechanic came back to check on what i was doing and he said i drilled crooked so now he had to widen the hole to tap it and widen it to get another bolt in... he does that, puts the pan back on and i tighten all the bolts and lower the hoist. i start my car and transmission fluid is spraying out, (like it was connected to a pressure hose) so i leave it on the hoist and let it go. i talk to him on the phone and ask why oil is spraying everywhere and he says i drilled into the transmission. a month later i tow it home. and at this point im wondering why its leaking, like i get into depth and search for the spot its leaking from. immediately when i get under the car and i look above the new bolt that he tapped and put in, and i see a hole right above it.. i look closely and see that its bigger than the drill i was using to drill out the bolt in the first place. me and my friend(the mechanics son) are trying to figure out why this hole is so big.... it turns out, by further looking into it, when the mechanic widen the hole and threaded it to make a bolt fit he drilled into the transmission when the car starts the fluid just sprays out of that hole.. theres is my story on my transmission......
the reason i told you that is becuz it helps me explain why im asking this question....
im to the point where i need to get my car running i got school, work and college are coming very quick, and there are threee daily driver for one car..when this problem first happened i wanted to do a manual swap.. well idk if thats gonna happen becuz i dont know a single thing about taking an auto trans out and putting the clutch kit in a new manual trans, and then bolting the manual one back up to the engine...
my question is this...
i dont know much about how to take the transmission off, how do i go about doing that?
second, how do i go about installing a new clutch kit in a manual trans and bolting that up?
can i do it at home in my garage... well i know i can but the real question is
can a person with no transmission replacment experience do this?
thanks in advance and thanks for listening to my rant also
PS please dont tell me that i need to look in the forums for a how to do on this stuff..i did and nothin comes up on it, none like a in depth or a how to.. just some things like "...you gotta unbolt the bolts fromt the engine.." i know theres more to that... please im in a deep situation and i really need your guys' help. please help me out the best you can.
thanks to all..
and if you think i should take another route, please advise on that,
some pics of the hole
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 02-26-2011, 08:02 AM   #2
ochowdero
the pics are as best as i can get...
i really want turbo
Old 02-26-2011, 10:00 AM   #3
ochowdero
before anyone yells at me i found a post with it
uhm question
is it still the same or basically the same for an auto trans?
http://www.cygnusx1.net/Supra/Librar....aspx?S=MT&P=4
and someone with no experience for installing a clutch kit ain a manual trans can it be possible for me too?
i really want turbo
Old 02-26-2011, 10:16 AM   #4
ochowdero
still didnt find a removal for automatic, only manualll
i really want turbo
Old 02-26-2011, 04:40 PM   #5
Sonyps307
Here is the how to for the auto and to do the 5speed swap you need.
•master
•slave
•lines between the master and slave
•clutch pedal
•shifter
•Transmission
•front part of drive shaft
•flywheel
•clutch and pressure plate
And a few other parts that I can't think of.
Also if you do a R154 swap get all the part that match That transmission and the same if u do the w58.
Old 02-26-2011, 05:08 PM   #6
Conga1991
Conga1991 is on a distinguished road
You also need to replace your wiring harness since your's is an auto you will need a manual, unless you like to bypass and splice a shit ton of wires. but easier to replace the harness for a manual. also get the same year as your car.
you're also better putting it up on a lift to get under it and take the 8 bolts off. personal experience of being under a car and taking it off was a pain.
not sure what tranny you're going to put it, but whatever one you get get the flywheel and clutch for that tranny, they have different bolts holes and wont match if you get two different ones. like if you get a w58 flywheel wont work with the R154, not sure if you didnt know that.
Get Redline tranny fluid, heard it was the best but I'm using Royal Purple and works pretty well for me, shifts like butter =]
Conga1991 is offline   Reply With Quote
Old 03-05-2011, 10:51 PM   #7
ochowdero
Bump! bump....
i really want turbo
Old 03-06-2011, 12:41 AM   #8
No it isn't the same... for some reason there is a different part number for the pre89 and the 89+ models... I've no idea what, never heard of anyone seeing a compatibility issue.
This wasn't with the tranny?
You're starting to get into an area where you're just going to have to see what's missing while you're doing it. You've got all the major stuff already covered in this thread.
All of the fasteners you're safe getting from a hardware store... just get hardened bolts according to the info in the fastener PDF which is somewhere in the FAQ. A fairly safe rule is that any fastener requires the same penetration as it's width at a minimum, 1.5x the diameter for hardened fasteners... hasn't failed me yet, but I generally try to get the fastener new from Toyota or match it up directly to the original.
Old 03-06-2011, 12:57 AM   #9
ochowdero
i need the fasteners, driveshaft, shifter and bushing, and the clutch fork..
and no the clutch fork didnt come with the tranny.
and i honestly cant find it anywhere..
anyway the car is coming together reall nice..
hopefully this will happen sooner then a month from now cuz i need my car back..
i just purchased flywheel bolts and pressure plate bolts,
i just received my clutch kit and should get my flywheel monday
i really want turbo
Old 03-06-2011, 01:27 AM   #10
I don't know the difference with that clutch fork, I'm assuming the bell housing and slave cylinder are different. You can use a clutch fork from a Cressida which may be easier to find in a salvage yard.
86.5 auto transmission removal HELP!!! elmer MKIII FAQ 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
