Old 02-16-2011, 05:10 AM   #1
Jay633
Jay633 is on a distinguished road
Default turbo i gone
apparently i have to replace my turbo. i was wondering if i should replace it with a stock ct26 or upgraded ct 26? and if i did upgrade what exactly do i have to do to run the turbo correctly? nd im talking bout the popular 57 trim for the ct26 i believe??
Jay633 is offline   Reply With Quote
Old 02-17-2011, 05:35 PM   #2
The 57 trim is a nice upgrade. IIRC, you shouldn't have any problems hitting fuel cut with it either while running just 7 - 8 psi.
Old 02-17-2011, 05:53 PM   #3
Jay633
so as long as i have stock boost levels i can run it perfectly fine as a bolt?? sweet
Old 02-17-2011, 06:08 PM   #4
I'm going off memory here, but I think the 57 trim puts you close to fuel cut but just under. The 57trim flows a higher volume and the charge is cooler. The amount of kinetic energy being fed to the engine at 7 psi is probably comparable to a stock CT-26 at 10 or 12 psi.
