Old 02-11-2011, 07:31 AM   #1
MKIIIPANdA
MKIIIPANdA is on a distinguished road
Exclamation fail waiting to happen? your thoughts?
Soooo i bout an 86.5 NA MKIII supra a little over a year ago for about 2 grand no problems ran fine until the first oil change which just lead to the major problem of losing oil from the head gasket.. changed all the gaskets.. still losing oils dumping it into where the spark plugs were changed the gromets and the gasket... after that started losing oil again.. but not burning it.. or into the head or leaking it out soo i rebuilt the engine ran well but then i had an accident due to some cosmic freak of nature that left me with about 5 grand in body work and frame straightening.. its like I was never meant to have a supra... but i just cant accept that ive been a toyota lover all my life my first car was an SR5 AE86 may she RIP now i plan on buying another 86.5 supra with a turbo swap has a manual transmission but an auto tranny the oil seal on the turbo may be gone according to the owner a leak in the front main seal and a wiring issue with the boost controller and running rich plus other assorted non mechanical issues.. i still have my crashed original supra... sooo what i need to know isss HOW DO I MAKE THIS WORK i want a turbo supra now i know imma have to buy some parts here and their but my ultimate goal is 300-350 WHP turbo whats the cheapest way to get their with what i got just give me all options im open for anything
MKIIIPANdA is offline   Reply With Quote
Old 02-11-2011, 11:01 AM   #2
Yes, you'd definitely fail any class I thought. My thoughts? Google needs to create an English to English translator.
Okay, I'll start and you finish; Once this is legible we'll discuss the car's problems.
Soooo, I bought an 86.5 NA MKIII Supra a little over a year ago for about 2 grand. No problems; It ran fine until the first oil change which just lead to the major problem of losing oil from the head gasket.. changed all the gaskets.. still losing oils dumping it into where the spark plugs were changed the gromets and the gasket... after that started losing oil again.. but not burning it.. or into the head or leaking it out soo i rebuilt the engine ran well but then i had an accident due to some cosmic freak of nature that left me with about 5 grand in body work and frame straightening.. its like I was never meant to have a supra... but i just cant accept that ive been a toyota lover all my life my first car was an SR5 AE86 may she RIP now i plan on buying another 86.5 supra with a turbo swap has a manual transmission but an auto tranny the oil seal on the turbo may be gone according to the owner a leak in the front main seal and a wiring issue with the boost controller and running rich plus other assorted non mechanical issues.. i still have my crashed original supra... sooo what i need to know isss HOW DO I MAKE THIS WORK i want a turbo supra. Now I know (imma - WTF?) I'm going to have to buy some parts here and there but my ultimate goal is 300-350 WHP. turbo What's the cheapest way to get there (their is possessive and nothing remotely related to there which indicated a location) with what I got have? Just give me all options, I'm open for anything.
Wow what a wreck; I now understand why you gave up on trying to fix it after writing it. Although, you did have the option of just throwing it all out and starting over. Well, you have my contribution; Orange = a note, pink = a deletion, red = a suggested correction. My grammar is far from perfect... but it's a start.
Good luck with the language and good luck with your car.
I will say this, your oil change didn't blow the HG; Nut unless you used nothing but Naptha, Seafoam or acid. It was already blown; It just didn't know it yet.
PS: If your posts are easy to read and decipher you're more likely to get and answer and far less likely to get harassed about your penmanship.
Old 02-12-2011, 12:17 AM   #3
mkiiisupra
If you want a turbo supra, buy a turbo supra that was that way stock from factory.
If you can avoid the year 86.5, your best bet is a 90-92 turbo. The later the better.
If the engine is in that bad of shape and it was swaped from a 7mge then i wouldnt go anywhere near it, no telling what he messed up.
Year Diffrences
http://www.musclecarclub.com/other-c...ta-supra.shtml
http://www.supramania.com/forums/sho...nges-for-MKIII
Block Diffrences
http://www.supramania.com/forums/sho...ate-GTE-Blocks
Info before buying
http://www.toyota-supra.info/forums/...ing-supra.html
http://www.toyota-supra.info/forums/...now-first.html
Oil on top of sparkplugs
http://www.toyota-supra.info/forums/...ark-plugs.html
NA to T conversion info
http://www.supramania.com/forums/sho...25-NA-T-how-to
1990 Toyota Supra Turbo A/T
Old 02-12-2011, 01:13 AM   #4
MKIIIPANdA
first things imma slang or shortened version of im gonna or as you would prefer i'm going to so yea sorry for the grammar but i guess thats why im not an english major :P and to the other guy haha sorry i forgot the names im bad with names uh thanks for the advice i know thats the truth but i just didnt want to let my 7MGE go to waste since i just rebuilt the thing and it only has 2000 miles but at this rate i think i might just fix up my AE86 and it would end up being cheaper then getting into a new supra
Old 02-13-2011, 10:28 PM   #5
depami
Year Diffrences
Block Diffrences
Info before buying
What's wrong with an 86.5?
Denny
82 5 sp 928 - Guards Red
92 FlightCraft 18 XLT
94 1200 Sportster
01 F150
Old 02-13-2011, 10:39 PM   #6
Other than age and that they weren't available with turbo? Not much... Some people have found some odd differences here and there in wiring and certain parts not quite fitting from other years. The early '89 model year was another anomaly where is wasn't uncommon to fine the odd '88 component here and there.
Old 02-14-2011, 12:38 AM   #7
Sonyps307
Some people say don't get the first year cars because they may have problems that Toyota didn't find or fix
Old 02-14-2011, 01:41 AM   #8
Not so much the case here. Other than the odd sized part here and there there weren't any problems which the MKIII didn't keep until at least '89 (or for the entire life of the model such as the HG torque spec and tail lamp failure module).
Old 02-16-2011, 01:53 PM   #9
MKIIIPANdA
ooohhh boy well i have an issue then since my supra is an 86.5 and the supra with the turbo swap is also an 86.5 hahaha what to dooo
does this happen to you guys 88Tsupra MKIII Supra 4 06-29-2007 07:56 AM
