Old 02-01-2011, 06:19 AM   #1
Conga1991
Conga1991 is on a distinguished road
Default Oil Leak and extra Plugs?? Help?!?!
So I have a oil leak, thought it was from the front oil seal and replaced it, started it a couple times and no leak. Ran it a bit more and it started drizzling oil from little gap from the lower timing cover. anyone have a leak like this or that came from the same general area??
Also the Plugs are from the wiring harness, one is white with 3 wires in it a red with yellow dots, a yellow with red dots and black with red dots. the other plug is yellow with 2 wires, blue and green. Not sure what they plug up to but Im thinking they could be the plugs to the california computer for the EGR?? If Im wrong please let me know.
Conga1991 is offline   Reply With Quote
Auto Supra Coolant hose pressure and return leak to oil pan and filter area? rjSupra MKIII Supra 45 01-18-2011 12:12 AM
Coolant Leak zcoolboard MKIII Supra 7 03-30-2009 06:54 PM
Leak Driver side floor baord ;( mkiiisupra MKIII Supra 2 12-07-2007 08:50 PM
Extra Cable? 808Supra MKIII Supra 1 08-17-2006 08:15 AM
