Old 09-16-2005, 01:36 PM   #1
bigal0043
bigal0043's Avatar
bigal0043 is on a distinguished road
Default Car on the road!!!!
so i finally got my supra on the road yesterday... my buddy was working on the hg for about 2 weeks now....
Did a mhg and arp studs... hardpipes and mostly all the hoses
runs really fast now loving it so much...
now my quesiton is i been keeping an eye on the temp and it stays right at normal temp... but anyway when i pop the hood after driving it around i can hear almost like a bubbling noise coming from around the thermostat area.... it is not constant like i hear it real quick then it would stop... any ideas? we were thinking it is just an air bubble in the collant or something
i just hope it isnt the hg or something like that...
bigal0043 is offline   Reply With Quote
Old 09-16-2005, 01:50 PM   #2
rnoswal
rnoswal's Avatar
I think that because that is a high spot in the cooling system that any air in the system will stay in that area until it all gets purged out. I know it might be a little work but having a temp guage that has numbers on it instead of the stock guage will give you a better read on temps. The stock one is so vague. Just make sure your shroud is on and the fan clutch is working and that you have a good radiator cap on so it can purge the system of air.
I am sure there are more opinions from some of the more experienced owners though, but that is some of my thinking on the sound. It could also be a noise that the idle control valve makes when the engine shuts off. It makes a similar noise but it is on the intake up high. Keep us informed.
Russ
Old 09-16-2005, 01:53 PM   #3
bigal0043
bigal0043's Avatar
k i was just worried that i blew the hg or something... after only like 2 days...
but yea i dont have a new radiator cap on there it is the same one as when i bought the car... any recommendations on a good one that i could pick up at like autozone or something?
Old 09-16-2005, 01:59 PM   #4
nickvash0104
nickvash0104 is on a distinguished road
Autozone caps are like $8 for a standard cap; I don't reccommend buying them as they go bad in about 3 months.
I'd say to spring for an aftermarket or a TRD cap
Black '87 N/A Auto
nickvash0104 is offline   Reply With Quote
Old 09-16-2005, 02:08 PM   #5
bigal0043
bigal0043's Avatar
cool thanks for the reply...
i am going up to the drag strip tonight... first time ever to drag anyone have any tips???
like when to launch ..shift points ..etc??
oh yea anyone have a link for someone who sells short shifters??? its such a long throw from 2nd to 3rd
car is a 87 turbo manual.....
Old 09-16-2005, 02:16 PM   #6
rnoswal
rnoswal's Avatar
Plus go for one, radiator cap, that holds the most psi, just to keep the water in if you are drag racing it.
Russ
Old 09-16-2005, 05:08 PM   #7
bigal0043
bigal0043's Avatar
another question.... my intercooler pipe near the turbo is getting hot what kind of heat wrap is the best to wrap the ic pipe????
also what does everyone launch at when they drag??? i was thinking at 5500 rpms but i am on a stock clutch
Old 09-16-2005, 06:21 PM   #8
SupraMan1784
SP58GT
5500rpm on a stock clutch...u can launch at that speed a couple times, but be wary its still stock so it might start slipping at the end of the night depending on teh amount of runs u do, as for shift points, im not sure about stock anymore since my ecu has been reflashed so its different, i have a higher redline and a larger powerband, but basically i try and shift towards the end of the powerband, somewhere near redline, if its your first time, i suggest short shifting the first couple rounds before you actually try and pinpointing the shifts...trust me a misshift is badd, for short shifters try b&m not because thats wut i have but its pretty reliable and well made, and there is less effort when going from gear to gear, look at ractive as well as twm...or is tmw...dont remember, for your last question on heat wrap, i use stuff from designengineering.com, i use their exhaust wraps on my headers, i dont really use it for the ic...doubt it would make a difference but take look at let me know
Old 09-17-2005, 02:25 PM   #9
bigal0043
bigal0043's Avatar
u lost me on the short shifters... where can i get one from... i have looked on like car websites but havent seen any at all
but thanks for the replies
Old 09-19-2005, 11:31 AM   #10
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
i would burp your cooling system and ensure that all is up to spec... last thing you wanna do is fix a hg and be a little low on water or a little irregularity and go racing and have it go ping!
park car on hill or jack up so radiator is at highest point
pull radiator cap (make sure car is very cool)
get bottles of water
start car
turn heater to hot and switch on to full
as it warms up and thermostat opens you should start seeing a few bubbles
as it is warming top up the radiator till bubbles are down to a minimum or none at all
when you think system is purged, cap the radiator, turn car off... let it down
see if you can still hear that odd bubble
there is a short shifter for sale in the for sale section i believe
also can be found on ebay
good luck at the drags
Pics of my build.
Do a diagnostic first!
Mk3 Supra Road Test Sinistral MKIII FAQ 8 02-14-2010 08:48 PM
twins or single for road racing? CougarDS MKIV FAQ 14 04-27-2009 06:51 AM
Max safe long straight performance in a road race? Humba MKIV Supra 7 12-25-2008 05:38 AM
November 2006 road and track. Florida Mike The Future of the Toyota Supra 7 10-01-2008 12:36 AM
Oxity Bank Note Road Rally Oxity-X Road Racing & Autocross 1 05-22-2006 12:54 PM
