Old 01-12-2011, 08:11 PM   #1
sd88supra
sd88supra is on a distinguished road
Question radiator plug broke!
I noticed I was leaking coolant from the radiator plug, so I go to replace it and find it's half broken, so I can't get it out (it's the plastic kind you screw in by hand). How can I go about removing it? I was thinking about making two slots with a dremel tool deep enough to take out with a phillips screwdriver. Anyone have a better solution?
I don't understand why anyone would make these stupid plugs out of plastic...
-1987 5 spd N/A with TEMS: low miles! All stock with the exception of electric fans and an '89 front bumper, Yokohama 225/50/16 with stock rims. It's a mess and in the garage.
-1987 5 spd Turbo with TEMS: miss-matched tires, needs lots of work, but it runs! Project car.
-1988 N/A auto targa: all stock except 18" rims with Falken 265/35/18 in rear and 225/35/18 in front; daily driver.
sd88supra is offline   Reply With Quote
Old 01-12-2011, 09:09 PM   #2
To remove the problem of dielectric corrosion resulting in a VERY common leaking point on older vehicles which originally came with metal plugs.
As for removing it, go buy an easy out.
Old 01-13-2011, 03:30 AM   #3
Green7mgte
Supra Forum Moderator
i dont know what he said, but im pretty sure he called you an asshole.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 01-16-2011, 10:49 PM   #4
sd88supra
haha, I meant why plastic and not some other composite that doesn't break so easily, though I suppose a properly insulated metal plug would work just fine.
Old 01-16-2011, 11:52 PM   #5
If you think plastic sucks when it breaks off just wait until you break off a bolt in there.
Besides, if you've got to tighten it so much that breakage is a common problem you're overtightening it.
oops i broke the headlight help supraluver4life MKIII Supra 13 12-22-2009 04:04 AM
Speedo cable broke. What next? Busted Knuckles MKIII Supra 5 10-25-2009 06:01 AM
Broke something.. and i dont know what it is. help. Kevin MKIII Supra 2 06-08-2009 12:10 PM
some f*ck broke my passenger window D_Train MKIII Supra 9 04-29-2007 09:07 PM
my 86 broke pittsupra MKII Supra 2 06-05-2006 11:42 AM
