Old 01-09-2011, 10:54 AM   #1
jeffseven7
jeffseven7 is on a distinguished road
Default 87 turbo manual randomly turns off when clutch pressed
When driving normal and the clutch is pushed in the engine just dies.....it doesnt do it all the time just say 1 out of 15 times
jeffseven7 is offline   Reply With Quote
Old 01-09-2011, 02:02 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
Any fault codes set? (tsrm will tell you how to check this)
http://www.cygnusx1.net/Supra/Librar...ection=FI&P=23
I'd suspect possibly a TPS or AFM related code but if it shows a normal condition then the likely culprit is the idle speed control (ISC) valve, testing & cleaning of which is also covered in the tsrm, tsrm in fact is your supra survival guide & should be added to your favourites list immediately
HTH
EDIT-: by the way, the SST (special service tool) referred to in the link I posted is simply a bit of wire you use to bridge the specified connectors...
Old 01-10-2011, 11:44 AM   #3
jeffseven7
Thanks ill check it out
1987 Turbo Black Manual
MODS:............................. Coming Soon:
Ct26 10psi................... Ct26 upgrade 57 or 60-1
Spearco FMIC............... 550 injectors
Greddy Type RS BOV ......Turbo Elbow
HKS 3000 pipe ...............and Downpipe
Apexi Turbo timer ...........MHG
3" Custom Exhaust ..........Forged Internals
Greddy Ti-C Muffler .........Lowered Suspension
Short Shifter...................Stage 2 Clutch+Fly
K&N Intake.....................HKS Mega Flow
Old 01-10-2011, 03:42 PM   #4
It's just choking? I presume your BOV is vented to atmosphere? That may be the problem.
89 7mg to 2jz turbo manual turbojuiced MKIII Supra 2 04-05-2008 01:11 AM
